Author Topic: XR16 and Router  (Read 1148 times)
Mike Caldwell
  • Covington, Ohio
Re: XR16 and Router
« Reply #10 on: August 11, 2020, 08:10:09 am »
Thank you! I will look into it more and see what I can adjust. I appreciate the help.
Also on the XR16 turn off the internal WIFI broadcast.
I have my systems set up more or less like all the suggestions here.
As mentioned get a WIFI scanner app so you can see what channels are in use and set you router accordingly, I check every location I set up in.
Last I checked they were only available for Andriod though. That works for me I mix with iPads but my personal tablet is Android.
On 2.4ghz there are only three channels that do not overlap with each other, 1, 6 and 11. Guess what three channels are used more often than not!
5ghz channels do not overlap one another.
Chrysander 'C.R.' Young
  • North Central FL
Re: XR16 and Router
« Reply #11 on: August 11, 2020, 11:08:48 am »
We use it for our outside services. I set it on top of the box that contains the mixer. The iPad is less than 50' away with clear view. I need to check for clarity of signal and the band but nothing else should be using it because it is only sending signal for the mixer. How do I verify the frequency is clear? I was under the impression that a router/modem would keep us from dropping signal.
Find a quiet place, turn down the lights, sit in a comfy place, light a candle, and repeat this mantra many times:
"I will never rely on wireless network access for mission critical services.  I will always have a wired backup."
I work as a network admin by day and a sound engineer on weekends.  I make my living doing this and the mantra above is the answer you seek.
Caleb Dueck
Re: XR16 and Router
« Reply #12 on: August 11, 2020, 06:36:40 pm »
Yes!  This should be screened next to the network ports on every digital console.
John L Nobile
Re: XR16 and Router
« Reply #13 on: August 11, 2020, 10:02:56 pm »
Wireless is a convenience. Don't rely solely on it. Always have a backup. You will use it.
Curtis McGill
Re: XR16 and Router
« Reply #14 on: August 15, 2020, 05:00:36 pm »
Dumb question coming: if I hide the SSID, how do I find the access point with my iPad to connect to the mixer?
Riley Casey
Re: XR16 and Router
« Reply #15 on: August 15, 2020, 06:09:17 pm »
Under "other network" type in the exact name of the hidden network and it will 'usually' find it.
Mike Caldwell
  • Covington, Ohio
Re: XR16 and Router
« Reply #16 on: August 15, 2020, 07:02:32 pm »
I've also found that it takes a little longer for an iPad to connect to a hidden SSID network.
Re: XR16 and Router
Page created in 0.031 seconds with 22 queries.
