Author Topic: Cyclic popping from DBX Zonepro 1060M  (Read 313 times)
David Allred
« on: August 05, 2020, 04:36:02 pm »
The problem was reported following a power surge after hours.  Assuming they followed protocol, the unit would have been off.  The unit is powered through a conditioner / suppressor that would also be powered down.  The popping cycles at approximately 1 pulse / sec and registers on the output meter of channel 1.  The other 5 channels are fine.  Channels 1-5 were connected to their respective amps.
It has been in daily operation since 2014.  I have switched thing around to eliminate ch 1 from routings.
The pops seem to be full spectrum (boom & tick).
Probably no repair will be planned for a while (if ever), but what is the most likely cause for this symptom?  Local repair shop or factory service required?
Thanks,
David
Re: Cyclic popping from DBX Zonepro 1060M
« Reply #1 on: August 05, 2020, 05:36:41 pm »
Failing capacitor...
Mike Caldwell
  • Covington, Ohio
« Reply #2 on: August 05, 2020, 08:15:54 pm »
Consider yourself lucky it's only one channel....for now, and your were able to re-configure the routing to channel 6.
Do you have the config backed up on your computer?
It's a long shot but it maybe worth doing a full hard reset and reloading the config.
If need be I would send it to DBX.
David Allred
« Reply #3 on: August 06, 2020, 10:13:32 am »
Had an amp do that once.  That is what I assumed it to be.  Thanks.
David Allred
« Reply #4 on: August 06, 2020, 10:16:38 am »
It is hard to remember after all these years, but I assume I do.  I'll connect and download next time I'm there to be safe, and try a reset.
