Pages: 1 [2] 3  All   Go Down
Author Topic: Field recorder for live stream?  (Read 981 times)
Brian Bolly
Re: Field recorder for live stream?
« Reply #10 on: August 03, 2020, 12:28:54 pm »
I am not an expert in field recording, but have had a lot of talks over the last few weeks with a friend who is, and have learned a couple key points:
  • On video shoots, the audio folks hold the responsibility of verifying frame rate and ensuring sync across all devices, including cameras
  • If you are using more than 1 camera, you need to make sure everything is syncd
  • If you are doing anything that is being recorded for later archival or editing, you need to make sure everything is syncd
  • If you are simply doing live to the web it is less important to have sync.  But often, someone will want it recorded (see above)
  • The cost of sync devices has come down significantly with devices like the Tentacle Sync, Denecke boxes, or NanoLockit.  If you are doing field recording, it's a small investment for some highly useful tools
  • The ROI on renting sync boxes to the client, even for their own cameras, is good (his words, not mine)
  • The audio guy needs to learn camera menus to set the proper frame rate (see point #1)
  • It is recommended that the audio guy carry the adapter cables to connect the sync boxes to the cameras - there are different pinouts and connectors, and don't expect the video guys to have them, ever (see Craig's recent thread on video)
So in short, a minor investment in a field recorder that can generate TC, and some remote sync boxes to hang on cameras, is small in the grand scheme of things to turn a bit of ROI back around and ensure proper sync everywhere.
« Last Edit: August 05, 2020, 08:31:08 am by Brian Bolly »
Dan Richardson
  • southern Vermont
    • NotTooLoud
« Reply #11 on: August 04, 2020, 08:28:34 am »
  • Web streaming is "24 fps" but not really - it's 23.976 in almost all instances.
Field recording and streaming are very different animals.
YouTube, Facebook, Twitch, and Vimeo, all recommend 30 or 60 fps. Never seen a recommendation for 24 fps, that's movie speed.
The vast majority of streams are run from cameras that don't even have sync capabilities. Webcams, iPhones, camcorders, PTZs, DSLRs.
« Last Edit: August 05, 2020, 08:08:40 am by Dan Richardson »
The best sound system is no sound system. Everything else is compromise.
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #12 on: August 04, 2020, 11:48:39 pm »
At this point in circuit design, there's no excuse for anything to not sound great. Sound Devices are head and shoulder above the others in build quality, but also in cost.
Sound Devices is BOCO all the way. But that's why you see little else on A list film/video shoots....
brian maddox
bdmaudio@gmail.com
Geert Friedhof
« Reply #13 on: August 05, 2020, 12:29:17 am »
Debbie Dunkley
  • Central North Carolina
« Reply #15 on: August 05, 2020, 12:45:37 am »
Mark Scrivener
    • My Recording Studio
« Reply #16 on: August 05, 2020, 01:06:27 am »
I'm sure the quality is great, but no plans for any real film/video shoots, and most of the sound devices units cost as much or more than the smaller digital mixers many of us use these days - Ui24r, X32 rack, etc. If I was doing location sound for a Netflix series, then no problem...but my use will be small, occasional location recording of solo artists or small ensembles. I'm even starting to wonder if I should just deal with a laptop and one of the old audio interfaces I have collecting dust. A high quality "run-n-gun" rig would be cool....just not sure I really need it.
Patrick Tracy
    • Boulder Sound Guy
« Reply #17 on: August 05, 2020, 04:22:29 am »
One caveat with the H4N is that it won't take a line level signal on the combo jack inputs.
My experience with the H4n is that the TRS is padded down relative to the XLR. On my H5 I can select a 20dB pad and it affects the XLR.
Scott Slater
« Reply #18 on: August 05, 2020, 06:16:43 am »
The Tascam DA-3000 ( https://tascam.com/us/product/da-3000/top ) is also a great choice IMO.  I've used it for years.  It has loads of I/O options and can record on multiple formats at multiple sampling rates.  It even supports DSD recording.
Brian Bolly
« Reply #19 on: August 05, 2020, 08:30:50 am »
Mea culpa - my cinema notes were next to my streaming notes and you're correct.  I will strike that from my original post.
Pages: 1 [2] 3  All   Go Up
Page created in 0.058 seconds with 22 queries.
