Author Topic: 1.5 inch trussing clamps  (Read 656 times)
Robert Marshall
« on: July 03, 2020, 11:43:24 am »
I wish to mount some small moving heads on my Gorilla Stands lighting bar that has a 1.5 inch truss. I bought some American DJ 1741000057 O Slim 2 Trussing clamps from Amazon in the UK but they diid not come with the inserts to reduce them to fit 1.5 inch truss. Does anyone know of a source? I cannot see them as available as a spare on the European ADJ site.
Thanks
Dennis Wiggins
Re: 1.5 inch trussing clamps
« Reply #1 on: July 03, 2020, 03:51:28 pm »
...mount some small moving heads on...1.5 inch truss.
Thanks
Are you looking for a C-type or O-type clamp?  Chauvet makes both types. I don't know about UK availability.
I've used the O-type CHAUVET DJ CLP-10 Light-Duty Adjustable O-Clamp for many years. Never a failure.
It has a 1.5" insert.
-Dennis
Art Welter
« Reply #2 on: July 03, 2020, 05:15:38 pm »
Pretty easy to make inserts from 1.5 inch schedule 40 PVC pipe using hand tools.
Don T. Williams
    • Q Systems Music & Sound
« Reply #3 on: July 03, 2020, 05:25:19 pm »
I made "do-it yourself" versions from plastic plumbing pipe.  Find 1.9" to 2" O.D. pipe with the inside diameter just bigger or even slightly smaller than the stand tube.  Carefully cut a slot on a length of pipe with a table saw - be very carefull!  Then you can cross-cut rings to the width you need and slip them over the stand's tubing.  Here a jig saw is safer, but I made jigs for both the rip and cross cuts.  It's not as easy as using the ones that come with the Chauvet CLP-10's but will work in a bind.  The slot usually gives you some adjustability and allows the ring to slip over the stand tube.  Again, be very careful or have someone else do it.  Plastic pipe and a table saw are a dangerous combination!
Jeff Lelko
  • Cape Canaveral, FL
« Reply #4 on: July 03, 2020, 08:29:43 pm »
Hi Robert, is there a reason why you didn’t just buy the right clamp to begin with?  They’re ~$5/ea., so not a tremendous investment!  DIY can certainly be done too but in the eyes of your insurance provider will probably be frowned upon...  Hope this helps!
Marc Sibilia
  • Princeton, New Jersey
« Reply #5 on: July 03, 2020, 09:50:23 pm »
Guy I worked with lost a pinky to that particular combination!
Brian Jojade
« Reply #6 on: July 29, 2020, 06:37:34 pm »
If you're putting lights on different size pipe, it's less of a hassle to drop in an insert vs having to constantly change clamps on fixtures.
Brian Jojade
Jeff Lelko
« Reply #7 on: July 30, 2020, 09:22:59 pm »
That's good rationale.  If functionality is a priority over cost and he's not hanging anything massive I'd think one could 3D print the adapters with good results if they can't be purchased individually.  I've had a handful of bits and pieces printed up for basically pocket change, so not bad at all for prototyping or wanting a simple yet professional solution.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #8 on: July 31, 2020, 11:39:28 am »
I have a set of clamps from (I think) the lightsource ? They are pricey but work from 1.3” to 2”.
Mark Cadwallader
  • Helena, Montana USA
« Reply #9 on: August 07, 2020, 01:50:23 am »
Global Truss has an O-clamp that fits 1.3" to 1.5" (35mm to 40mm IIRC) with no insert required.  I have a number of them for pipe and drape uprights and light weight tripod lighting stands.
Page created in 0.066 seconds with 24 queries.
