Author Topic: Crest Audio FA1201 low volume + clipping  (Read 348 times)
Bobby Saraceno
« on: April 15, 2020, 03:15:02 pm »
Hello, this is my first post. I'm building a PA system to use with my band and I just got a Crest Audio FA1201 power amp for a song on Craigslist. I brought it home and connected it to my Peavey sp2 xt 8 ohm PA speakers. I hooked my bass up through a DI into the input and all I could hear was a distorted signal at low volume despite the channel volume control being up almost half way. This is my first time purchasing a power amp, I actually have never used one before because I always used powered mixers. Due to the things being the way the are now, I can't exactly take it to a repair shop. If anyone has any tips or advice, please let me know. Thanks in advance
Re: Crest Audio FA1201 low volume + clipping
« Reply #1 on: April 15, 2020, 03:25:18 pm »
The DI's output is closer to mic level than line level so that you have little signal does not surprise me.  That it is distorted could be a couple of things - the bass is overdriving the DI input (active bass, inexpensive passive DI) or perhaps there is a bad cable/connector, or that the amp needs to see Dr dB for repairs.
Your powered mixer likely has a line output of some kind.  Hook that up to the Crest, use some tracks from your phone or a CD, or just plug in a vocal mic. What comes out of the speakers?
Bobby Saraceno
« Reply #2 on: April 15, 2020, 05:17:48 pm »
That works great with the mixer - everything's perfect now. Thanks for the quick advice! playing music through it works great - and micing my amp works great too.
Craig Hauber
« Reply #3 on: April 16, 2020, 02:01:51 pm »
That amp could be from as far back as the late 80's and it was one of the larger output models of the series, meaning quite a bit was crammed in 2 rack spaces in an era when that was quite bleeding-edge technology so quite a bit could have gone wrong with it in the last 30 years!
I still have one in my "museum" and even with an 1/8" to XLR adaptor setup my phone doesn't drive it all that loud either -so anything through a D.I. box doesn't stand a chance!  That being said, the phone does give it enough level to verify it is working fine.
-Even a phone with a headphone jack is now considered "antique" so I'm amazed my 32 year old amp still works!
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Page created in 0.097 seconds with 22 queries.
