Author Topic: Small light show control  (Read 1109 times)
Tony Stubb
« on: February 28, 2020, 11:37:28 am »
Hello,
   Iím the sound engineer for a small 5-piece rock band.  Recently I picked up a generic set of LED pars with stands.  I have been doing sound work for over 30 years.  I have never ventured much into lighting but have always supplied basic wash lighting.  I mix wireless from a Laptop to a 5g router thatís connected to my rackmount mixer.
  What I would like to do, if possible, is provide real basic lighting control from the laptop.. 2.4mhz wireless wonít work, too congested.  So I would like to load a lighting software package on my laptop and control the lights from the Lan port on my router.  I have been some research, but Iím not sure what I need to do this, so far it looks like this.
Laptop wireless connection to the router.
Control Software on the Laptop
Router Lan port to a Ethernet to DMX adapter.
Jump DMX cables from light to light.
Address all lights and being their generic off brand, do a manual channel setup in the software.
Cost is a concern, looking to do this on the cheap.
What budget friend equipment and software, do I need to accomplish this! Is this even doable!  And can the lighting software run from the same laptop I mix from.  Windows 10 with plenty of Horsepower!
Thank You for your help!
John Fruits
Re: Small light show control
« Reply #1 on: February 28, 2020, 12:28:45 pm »
Welcome, one problem with your post.  This forum requires the use of your real name.  Until that is fixed we aren't allowed to answer.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Kevin_Tisdall
  • Milford, CT
« Reply #2 on: February 28, 2020, 01:19:41 pm »
Hello,
Look into either the wired-ethernet or usb versions of dmxking or enttec boxes to get from the pc/lan to dmx.    Not sure what apps for the PC ( I use luminair on ipads ).    I found the donner 2.4ghz dmx wireless systems are pretty robust even in busy 2.4ghz environments.  At least mine have never failed in various clubs and community centers.
I followed Debbie Dunkley's setup (search the lighting forum) with Ipad-luminaire3>*wifi*>AP>dmxking>donner2.4xmit>*2.4ghz*>donner2.4ghzRCV>dmx cables between lights on a stand>terminator.
Seems to work.
--Kevin
Steve Garris
« Reply #3 on: February 28, 2020, 02:06:20 pm »
Hello,
I was going to try to do this with an iPad, but realized it wasn't going to work. I know you can use the same router as FOH and dmx, but the running of both programs might be a program, and/or device specific.
FWIW, I run my sound on 1 iPad and my lights on another iPad using Luminair3. I also use the Donner wireless units with excellent results. You don't need cables.
Tony Stubb
« Reply #4 on: February 28, 2020, 02:06:48 pm »
Seems to work.
--Kevin
Looking at the Donner wireless system.  I take it I need one transmitter for the USB to DMX converter output connection.  Do I need just one receiver for the first light in the chain or one for each light?
Tony Stubb
« Reply #5 on: February 28, 2020, 02:13:23 pm »
I think one laptop will work, due to the fact I'm running a SoundCraft mixer and it uses a web browser for control, no specific app needed for the mixer. I can run other programs in the background and log into the web while mixing I've tested this so a lighting app should work but doesn't mean it will.
Dave Garoutte
  • San Rafael, CA
« Reply #6 on: February 28, 2020, 06:23:46 pm »
Yes.
One Rx on each tree, and any other chains.
TX on the (I prefer) DMXKing output.
Works fab.
Mal Brown
« Reply #7 on: March 03, 2020, 02:26:46 am »
unless you are willing to truly commit... you are better off with generic hardware dmx board and thee donner wireless setup. I was an early adopter of Luminair. They decided that bug fixes were upgrades.  So I would have to purchase Luminaire again...  fuck that.  I understand other  folks have had success with Luminaire later versions. Burn me once, same on you... Burn me twice...
Currently I have a laptop dedicated to Onyx and an M-TOUCH controller.  It is not an insignificant learning curve.  Unless you are going hog wild i terms of channels one of the $60 Obey70  clones can go a long way.
you can see some of our lighting on fb as Gorge Sound and Light
Bass player, sound guy.
Fb Gorge Sound and Light
WillyandNelson.com
Mark Norgren
  • Mark Norgren
« Reply #8 on: March 03, 2020, 07:15:55 am »
I have been using the Donner stuff for awhile and had good luck with them!  I bought one transmitter and three wireless receivers.  One receiver for each tree and one for lights by the drums.  I can run lines from each fixture depending on how elaborate I want to go.  We also have been using QLC+ on my MacBook Pro with great results.  FWIW
Robert Marshall
« Reply #9 on: April 26, 2020, 12:46:52 pm »
Yes.
Works fab.
Thanks Dave,
Just to confirm I want to use this system to control the following from a Pioneer RB-DMX1 interface:
1 x Kam Partybar
2 x Stagg Headbanger XT10s (slaved together)
2 x ADJ Inno Pocket Spots (slaved together)
1 x Kam Floodbank
Am I correct in understanding that one Donner DMX transmitter and three receivers will be enough to do this?
¬ę Reply #9 on: April 26, 2020, 12:46:52 pm ¬Ľ
Page created in 0.104 seconds with 22 queries.
