Pages: [1] 2 3   Go Down
Author Topic: Ground Loop What to do? Should I bother?  (Read 2543 times)
frank kayser
« on: February 18, 2020, 05:36:22 pm »
Hi folks,
We've had a ceiling mount projector tied into our Touchmix16 for years now without issue.
Last night I get a panic call - can't get any volume out of the DVD player.
I get in, loud buzz, little signal.  I swap out HDMI cable, audio cable.  Still a loud buzz overwhelming any signal.  30 minutes to showtime, I abandon that setup. An organizer brings in a replacement projector.  Lots of adapters later, all running 15 minutes before meeting.
So last night I firmly believed there was an issue with the audio section of the projector.
I pulled the projector down today, plugged it in next to the mixer, and no noise.  What?
I plugged it into the original socket and voila! Noise is back.  Oops... Ground loop. Where did that come from?
Other than moving the projector to be on the same circuit as the sound system, the only thing I can think of would be to use a "cheater" plug, disconnecting the ground.  That's a non starter.  Lift the ground on the audio cable?
While writing this, I had a D'Oh! moment.  I have been assuming up to this very point that the change was somewhere else in the cafe. It just occurred to me that it may not be in the rest of the cafe, but the stage itself where something is leaking to ground.  A number of "new" powerstrips have appeared over the last little while.  I suspected a power strip originally hanging off the projector outlet, but disconnected, no change.
How would I test (measure)?
NCVT should tell me if any voltage is on ground, no?
Measure voltage between ground at sound system and the ground where the projector was plugged in.  That would identify the existence of the ground loop, but not which outlet/circuit is at fault.
Voltage measured between neutral and ground?
Between hot and ground?
Any type of load required to test?
The last question (that I have now) is how much effort should I (non electrician) put into tracking it down?
frank
Chris Hindle
Re: Ground Loop What to do? Should I bother?
« Reply #1 on: February 18, 2020, 06:15:56 pm »
Start unplugging shit until the noise goes away?
A leaky MOV in a power strip *could* be causing this...
Chris.
Jeff Lelko
  • Cape Canaveral, FL
« Reply #2 on: February 18, 2020, 07:09:45 pm »
Yep.  Pesky issues like this are often traced to the most unsuspecting components.  Just recently it took me over an hour to troubleshoot a ground loop on a medium-sized outdoor system - the whole problem boiled down to a single TS cable that was supposed to be TRS...  Good luck!
Brian Jojade
« Reply #3 on: February 18, 2020, 07:31:04 pm »
Are you taking the audio feed out of the projector??  If so, are you converting the audio feed to a balanced connection and using isolation transformers?  Unbalanced connections tend to be much more finicky for buzz, and not running through isolation can make it even worse.
Brian Jojade
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #4 on: February 19, 2020, 05:09:10 am »
This man knows what's up. This is your solution.
You need to put a DI or isolation transformer in between the projector and the desk. It is entirely likely that the projector's caps have started leaking and there is stray voltage going to the ground from the projector itself.
There is a also a likelihood that the ground connection on the projector's plug has went faulty and now the only ground connection is the audio cable, therefore causing your buzz. The ground connection's impedance might have just went up significantly enough the the lowest impedance is now the audio cable's shield and therefore more current is going down there than to the earth on the power plug.
Audio Technician
Word & Life Church
- Ivan Beaver
Kevin Graf
« Reply #5 on: February 19, 2020, 08:55:35 am »
Check for a mis-wired power strip that swaps the Neutral & Safety Ground.
a 3 LED tester won't find this.
Speedskater
Taylor Hall
« Reply #6 on: February 19, 2020, 09:31:24 am »
This. We use a DI or TIGLBOX whenever there's a 3.5mm connection in play, worth their weight in gold and solve 95% of hum issues with the flick of a switch.
1) Do it right
« Reply #7 on: February 19, 2020, 10:50:54 am »
If the audio has to come from the projector - Radial Stage Bug 5 or Rapco's similar model.
frank kayser
« Reply #8 on: February 19, 2020, 11:57:08 am »
Again, thanks to everyone for their input.  Lots of good ideas.
I'll go over the stage with a fine tooth comb.  As I mentioned, some power strips have "appeared" over the last month or so.  I had bought some unfiltered direct power strips, but found others liked them more than we did, if you get my drift.
And yes, a Radial SB5 or the like would be good insurance for the future, whether I find the fault or not.
Thanks to everyone.
frank
Keith Broughton
  • Toronto
« Reply #9 on: February 19, 2020, 02:29:59 pm »
frank
Start with this , get clean audio, then look for a potential fault.
There doesn't necessarily need to be a fault to get a ground loop to a projector.
Pages: [1] 2 3   Go Up
Page created in 0.037 seconds with 22 queries.
