Author Topic: help to cluster 4 horn subs  (Read 777 times)
Rolando Saenz
« on: February 04, 2020, 07:47:31 pm »
Guys,
what is the best way to cluster 4 horn subs
See pic
A,B,C or D
also, it is possible to do a cardioid arrangement with 4 cabs ?
i saw one time a guy who put 2 cabs , one in top of the other the top one facing to the back
and he inverted the polarity on the top one
i didnt had the chance to hear it
Bob Stone
Re: help to cluster 4 horn subs
« Reply #1 on: February 04, 2020, 08:34:13 pm »
Arrangement A and unlikely to do cardiod effectively with LA400's.
Steve-White
« Reply #2 on: February 04, 2020, 08:51:44 pm »
None of those clusters will be appreciably different.  "A" is probably the most correct and therefore the "best" as has been alluded to.
But, you would be hard pressed to really notice any differences.
Bob Faulkner
  • Raleigh, NC
« Reply #3 on: February 05, 2020, 06:43:01 am »
Guys,
See pic
A,B,C or D
As was referenced in a previous post... look at option "D".  Now, spread those subs across down-stage with a 1/4 wave length spacing between them of the bass frequency you would like to emphasize.  Not knowing what type of music you are mixing for, you may want to try a 12ft (3.6m) spacing between the cabinets to start with.
If you want to do cardioid, you may need to have a way to delay the rear-firing cabinet (depending on your setup).
« Last Edit: February 05, 2020, 06:45:09 am by Bob Faulkner »
« Reply #4 on: February 05, 2020, 10:33:07 am »
So long as the subs are within 1/4 wavelength of each other they will couple.  At 80Hz that's a little over 4 ft.
Bob Stone
« Reply #5 on: February 05, 2020, 10:57:56 am »
With horns though, isn't there a coupling of the horns too rather than just the sound waves when they're placed close together?
Rolando Saenz
« Reply #6 on: February 05, 2020, 11:37:05 am »
Thanks for the advice comments
i do not have the LA400's ( i wish)
i have 4 b52 LX18's that looks like the CV L36 , so is the same principle i guess
i acquired them for $500  all four
also an  FP10000Q  preowned SANWAY clone that i bought for $400
A guy in town swapped the original drivers with  B&C 18TBX100
does the TBX100 will fit the LX18's ?
« Reply #7 on: February 05, 2020, 12:12:54 pm »
Bob, what makes you think horns defy the laws of physics?  The acoustic outputs will still couple.
Tight packing horns gives you a larger horn "mouth" area, which lowers the cut off and increases directivity... Maybe Ivan can expound...
« Last Edit: February 05, 2020, 12:15:09 pm by Tim McCulloch »
Miguel Dahl
« Reply #8 on: February 05, 2020, 01:33:35 pm »
I remember when I still saw the TSW-721 once in a while here and there, and I always saw them placed or stacked mouth-to-mouth.
Randy Pence
  • Berlin, Germany
« Reply #9 on: February 05, 2020, 02:25:04 pm »
how about option e? lay them on their sides and stack them up
Page created in 0.09 seconds with 24 queries.
