Author Topic: Need to jury-rig an old Shure LX transmitter antenna  (Read 2512 times)
Brian Gowing
    • Gowing Associates
« on: April 03, 2011, 04:38:23 pm »
A church that I help out has an old Shure LX bodypack for a lav mic that the antenna has broken off. The church can't afford to replace the system so is there a way to either replace the antenna or jury-rig an antenna so they can have a workable pack for at least the next few months until they can get the funds to replace it? The antenna is broken on the bodypack right at the rubber nipple where it enters into the pack.
Any suggestions would be appreciated.
Thanks,
Brian
Brian Gowing
Technical Consultant
Christian & Missionary Alliance
Gowing Associates
Lee Buckalew
  • St. Louis, MO area
    • Pro Sound Advice, Inc.
Re: Need to jury-rig an old Shure LX transmitter antenna
« Reply #1 on: April 03, 2011, 06:26:51 pm »
Thanks,
Brian
Brian,
Contact Shure at 1-800-516-2525.  This is the service department.  They could tell you if you can get the antenna.  They typically have a very reasonable service policy.  Here is a link to the service fee chart.
http://www.shure.com/idc/groups/primary_content/@americas/documents/webcontent/pdf_en_us_service_fees.pdf
Lee Buckalew
Lee Buckalew
Brian Gowing
    • Gowing Associates
« Reply #2 on: April 03, 2011, 09:07:26 pm »
Brian,
Lee Buckalew
Thanks Lee!
Brian Gowing
Gowing Associates
Gus Housen
« Reply #3 on: April 04, 2011, 06:20:04 pm »
You migt cut a chunk of wire the same length and solder it where the antenna was
Lee Buckalew
« Reply #4 on: April 04, 2011, 09:00:38 pm »
Yes,
You can cut an antenna to length by comparing to the existing unit (be sure to include the length all the way to the PC board).
I have most frequently used lav mic cable for this.  If you got some dead lavs around this can work well.
If the part is available from Shure, the swap is very easy (as long as you are comfortable soldering and taking apart the pack) and the cable will fit the strain relief properly, etc.
Lee Buckalew
Lee Buckalew
Page created in 0.064 seconds with 22 queries.
