Pages: 1 2 [3]  All   Go Down
Author Topic: Trunk ports in the Yamaha SWP1-switches  (Read 1981 times)
Miguel Dahl
Re: Trunk ports in the Yamaha SWP1-switches
« Reply #20 on: January 23, 2020, 01:34:20 pm »
Well it doesn't matter if it's 10 cm or 100 meters foh-stage if the cable is 100 meters...
Maybe I'm misunderstanding something here? Our cables are 100m, endpoint to end point, always worked flawlessly. From what I read from the poster above here it was something like  "If you're planning for a 90 meter run, and it turns out you need do run it elsewhere than planned, you might have to go 115m".. We're not running into those situations, as we don't have long runs, and have lots of spare on the reel if we would need to go longer than our pretty standard 50-60 meter runs. 100m is up to spec, and it haven't let us down yet. I don't understand why a standard which is stated from the maker of the equipment used, confirmed by real life usage should suddenly not work unless there's some damage done to the equipment.
« Last Edit: January 23, 2020, 01:42:06 pm by Miguel Dahl »
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #21 on: January 23, 2020, 05:24:51 pm »
That last sentence is the key.  100m is the upper standard limit and so long as your cable is within spec and undamaged, it'll work just fine.  But cables DO get damaged from normal wear and tear and that damage is often not visible externally.  This combined with the cable being at the upper limit of the standard can combine to create intermittent failures, which always seem to show themselves AFTER the show starts.
None of this means you're wrong to use the cable you're using.  You know your gear and you know your show situations.  But those of us who are often using OTHER people's gear in perhaps a wider variety of show situations tend to be a bit more cautious.  Up to about 50m i prefer copper for it's simplicity and at those distances there is a little bit more wiggle room if there a small crimp in the cable of whatever.  But past that i'll take fiber every time.  It's just a safer alternative.
brian maddox
bdmaudio@gmail.com
Jelmer de Jong
« Reply #22 on: March 15, 2020, 06:54:02 pm »
Add to it that every (ethercon)patch in between eats away roughly 5 meters of the 100 meter max.
Pages: 1 2 [3]  All   Go Up
Page created in 0.113 seconds with 22 queries.
