Poll
I don't know how to remove this poll thing
- 1 (33.3%)
- 1 (33.3%)
- 0 (0%)
- 1 (33.3%)
Total Members Voted: 3
Author Topic: DMX512 Problems  (Read 840 times)
Lucas Smith
Re: DMX512 Problems
« Reply #10 on: November 27, 2019, 05:04:14 pm »
Lucas, try setting all of your matching lights to the same starting dmx address. With the same address and inputs, they should all do the same thing at the same time. If they don't, there is a problem with one or more of the lights not passing a dmx signal through the fixture on to the next fixture.
Just tried that, got the exact same problem as soon as I plugged in the second fixture (1st light working and cables all working and the light plugging into works aswell when its just that one plugged into the controller) the first light stopped blinking red at the back and went black as well as the second one even though I have some of the dimmers up which were working on the first light.
Mark Cadwallader
  • Helena, Montana USA
Re: DMX512 Problems
« Reply #11 on: November 27, 2019, 05:23:29 pm »
Did you try a different unit as #1 in the series?  I assume each light is correctly powered from the mains service.
Jeff Lelko
  • Cape Canaveral, FL
Re: DMX512 Problems
« Reply #12 on: November 27, 2019, 05:56:42 pm »
Along the lines of what Mark is helping you to single out, I think one (or more) fixtures isnít passing through clean DMX.  Iím going to go out on a slight limb and say one of two things is going on.
- An electrical problem (stray voltage leaching into the DMX circuit or ground), or
- A fixture still thinking itís in Master/Slave mode and acting accordingly, trying to control the other fixtures in the daisy chain.
As annoying as it will sound, getting some tape and markers to label every fixture and playing with the different combinations is the most straightforward way to find the bad light short of having diagnostic equipment.  Hope this helps!
Paul G. OBrien
Re: DMX512 Problems
« Reply #13 on: November 27, 2019, 06:06:34 pm »
I'm going to suggest you put all fixtures in slave mode and if they can be set to have a different number of control channels.. 3ch or 5ch for an RGB fixture for example, set them to the lowest number so that you just have intensity control for each color.
Often fixtures like this will automatically switch to master/slave mode and ignore the controller when 2 or more are linked together unless all are set to slave.
Lucas Smith
Re: DMX512 Problems
« Reply #14 on: November 28, 2019, 12:15:48 pm »
Unfortunately these lights dont have a option where you can control the number of channels it is using. But just now I got three of them to work though. I think the problem is because some fog liquid spilled onto the lights and I cleaned them but maybe it is messing with the signals?
Jeff Lelko
Re: DMX512 Problems
« Reply #15 on: November 28, 2019, 12:25:36 pm »
I can promise that fog fluid in the lights definitely wonít be doing you any favors!  My vote is still that you have an electrical problem in at least one of the fixtures somewhere (fog fluid induced or not).  At least you got three of them working!  Honestly though, these fixtures are, what, $10 each?  Mileage with these types of units vary greatly.  It might be worth your while to spend a bit more and get something more standard and reliable.  Itís just a question of what itís worth to you.  Glad youíre making progress though!
Lucas Smith
Re: DMX512 Problems
« Reply #16 on: November 28, 2019, 12:27:44 pm »
Yes I might open them up and see if there is any damage or liquid still there!
Paul G. OBrien
Re: DMX512 Problems
« Reply #17 on: November 29, 2019, 11:09:58 am »
What about setting master slave mode? Your success rate will be nothing but random until all fixtures are in slave mode, then they will work perfectly every time... assuming there are no internal electrical problems. I find the soldering quality inside really cheap fixtures can be pretty terrible sometimes, easy fix though if you are at all handy with circuit board sized soldering iron.
Re: DMX512 Problems
¬ę Reply #17 on: November 29, 2019, 11:09:58 am ¬Ľ
Page created in 0.058 seconds with 25 queries.
