Author Topic: 8ch rig for 18 cities in USA and 8 in Europe in 2020  (Read 666 times)
Loren Miller
« on: November 15, 2019, 05:06:04 pm »
This is still in its infancy but I might be putting together an 8ch rig for major cities in the USA and a handful of European cities (UK, Spain, Germany, France, Portugal and Italy)
The main reason to put our own rig together was the huge difference in quality from city to city and vendor to vendor. The countryman headsets that I put in the request were typical countryman, broken. Then came the scramble. Eventually started to request DPA but costs went through the roof. So I am toying around with putting together a wireless rack and just add it to the freight truck between shows.
I assume to do this tour with 1 rig I need as much spectrum as I can get, but Europe adds some variable I am hoping you guys can shed some light on. I've done some preliminary research and it seems that UHF is good for Europe (I know crazy license in UK required).
Question: Can ULXD swing this in 1 freq or am I gonna have to mortgage the farm and get axient?
Gig: all taking head corporate bread and butter
Thanks,
Loren
John Sulek
  • Toronto Canada
Re: 8ch rig for 18 cities in USA and 8 in Europe in 2020
« Reply #1 on: November 15, 2019, 05:14:49 pm »
Thanks,
Loren
 To cover that many regions...I would look at wideband tuning tx and rx like Axient D, Wisycom, perhaps Senn 6000 but the tx aren't as wide tuning range as the rx.
 When I upgraded an artist's kit in 2018, we couldn't find a single ULXD freq block that we could be confident to find clear spectrum for, in all North American and UK markets as things move forward.
« Last Edit: November 15, 2019, 05:27:30 pm by John Sulek »
Ike Zimbel
    • Zimbel Audio Productions
« Reply #2 on: November 15, 2019, 06:27:27 pm »
What John said. I recommend Axient Digital. I have used it successfully all over the US and Canada, in the UK, Ireland, France, Germany, Belgium, Switzerland, Australia, New Zealand and Japan. As soon as you have to buy two of anything cheap, (because of band issues) you may as well spend the $$ and get AD. Buying two of the 4 Ch receivers should offer some savings over buying four two channel systems.
~Ike Zimbel~
Wireless frequency coordination specialist.
Radio Active Designs
~416-720-0887~
Loren Miller
« Reply #3 on: November 16, 2019, 12:23:03 am »
thanks for confirming my suspicions!
I didnít know that the senn 6000 tx are narrower than the rx, that seems questionable?!?
My only complaint about Axient is the location of the power switch on the HH, turns a 1 hand operation into 2, very minor but annoying as all get out every time I use them?!?
Russell Ault
  • Edmonton, AB
« Reply #4 on: November 16, 2019, 01:37:16 am »
It's classic Sennheiser (Lectro did it as well). Wideband receivers (with less space constraints) are easier to build than wideband transmitters, and most of the top-tier Sennhieser gear out there (think 5212s, etc) will have two or three (or more) bands of TX per band of RX.
You mean to say that you don't lock them out?
-Russ
Daniel Levi
« Reply #5 on: November 16, 2019, 07:25:34 am »
Though I will preface this with tye fact that wireless systems are not my area and I have not used them so can't comment on the quality the only option I know of for wideband rx AND tx is the DB Technologies MOVING D or RS1600 which has a frequency range of 470-870 MHZ (with 1600 channels), with even the log periodic antenna they supply being designed for the full frequency band.
Just on appearance and features they look to be at least mid range quality wise.
As for capsules the handhelds are Shure compatible and the bodypacks are Shure/Beyerdynamic compatible 4 pin mini-XLR.
https://www.dbtechnologies.com/en/products/radio-systems/touring-rack-moving-d/
https://www.dbtechnologies.com/en/products/radio-systems/rs16000/
« Last Edit: November 16, 2019, 07:30:30 am by Daniel Levi »
Ike Zimbel
« Reply #6 on: November 16, 2019, 10:37:27 am »
Yes, there are two TX bands in D6000. A1-4, 470-558 MHz, and A5-8, 550-638 MHz. I've used these in all the areas mentioned in my earlier post and they worked quite well, too. The two band thing is a bit of a pain, but the 8 MHz overlap between the two bands can be quite helpful if you put your spare TX's there. Of course, that's only useful if that 8 MHz is free of DTV...
~Ike Zimbel~
~416-720-0887~
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #7 on: November 17, 2019, 02:11:54 am »
Just a question, why wouldn't you just buy the countryman headsets you need with all relevant adaptors and the just rent the wireless locally? I'm sure that in all the places you are planning on going there is decent providers for the actual RF equipment.
Audio Technician
Word & Life Church
- Ivan Beaver
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #8 on: November 17, 2019, 05:19:18 am »
^ +1. I had the same thought - this has to be the easiest way.
Chris
www.grimshawaudio.com
Loren Miller
« Reply #9 on: November 17, 2019, 07:26:32 am »
-Russ
[/quote]
For everyone else Yes, but my HH I like to on/off myself.
¬ę Reply #9 on: November 17, 2019, 07:26:32 am ¬Ľ
Page created in 0.057 seconds with 23 queries.
