Author Topic: PA Power amp Connection Question  (Read 1081 times)
Scott Gray
« on: October 22, 2019, 01:38:27 pm »
This should be an easy answer, but I cannot find it online.
I have a Behringer Xenyx 1222 mixer and just purchased a Behringer NX4 6000 to replace the existing power amp. The mixer has a L & R main output. The NX4 has A,B,C,D input and 4 channels out (ABCD). How do I connect the L & R out to the power amp input and have A, B, C, and D outputs with independent volumes on each?
Y adapter seems the obvious solution, but some people seem to think Y cables should not be used??
Any thoughts would be greatly appreciated.
Keith Broughton
  • Toronto
Re: PA Power amp Connection Question
« Reply #1 on: October 22, 2019, 01:44:13 pm »
I see no  reason Y adapters will not be suitable for your application if the on board switches don't give you input configuration options.
Mark Cadwallader
  • Helena, Montana USA
« Reply #2 on: October 22, 2019, 05:49:02 pm »
The general rule of thumb that I learned is that it is okay to split a signal with a wye cable, but don't combine signals with a wye.
Geert Friedhof
« Reply #3 on: October 22, 2019, 06:08:17 pm »
Put both 'mode' switches in mono, and both 'crossover' switches at full range.
Put Left and Right from the mixer in A and C respectively.
A and B will be Left, C and D will be Right.
Scott Gray
« Reply #4 on: October 22, 2019, 10:03:34 pm »
I thought it should be something like this, just didn't have the correct combination. Thank You.
Scott Gray
« Reply #5 on: October 23, 2019, 09:25:39 am »
OK, so I connected this way. Now on the power amp A = left and C = right but B and D volume controls do nothing. I'm trying to get a L & R Mains and L & R Monitors all with independent volume controls.
There's not many switches or controls, is there anything else I might be missing?
« Last Edit: October 23, 2019, 09:28:43 am by Scott Gray »
Taylor Hall
« Reply #6 on: October 23, 2019, 10:21:37 am »
If that's the case you will need to undo the switch settings that linked AB and CD and run individual inputs to each channel. Linking channels like you did before will only let one gain knob per linked pair control the sensitivity.
1) Do it right
Scott Gray
« Reply #7 on: October 23, 2019, 10:34:05 am »
Agreed, it looks like splitters (Y cables ) then.
Thank You.
« Reply #8 on: October 24, 2019, 12:55:03 am »
Thank You.
You should not be controlling volume at the amp.  Doesn't your mixer have aux feeds for the monitors?  If not consider an XR-12 as an upgrade to that mixer.
Debbie Dunkley
  • Central North Carolina
« Reply #9 on: November 29, 2019, 10:00:41 am »
I agree.  Monitors require a mix that's different from house, which is usually accomplished by aux mixes.  (Some boards call them by different names.) Each aux mix has its own dedicated output from the board, which feeds into its own designated input and corresponding output on an amp (assuming a passive speaker system).
Hey Carl... Welcome to the forum but you will need to change your display name to your real name as per the forum rules you agreed to when you joined. Just a  heads up ......
Page created in 0.091 seconds with 23 queries.
