Author Topic: Issue with weird sound coming from Behringer keyboard amp  (Read 530 times)
Jonathan Dignam
« on: October 06, 2019, 10:27:08 am »
Hi guys. I am getting this strange sound from my Behringer Keyboard amp. Here is a link to youtube where you can hear the issue. Any help would be great. Thanks. https://youtu.be/ZFccB20xS8w.
Mike Caldwell
  • Covington, Ohio
Re: Issue with weird sound coming from Behringer keyboard amp
« Reply #1 on: October 06, 2019, 11:59:50 am »
Is that noise coming directly out of the amp?
Are you connecting the amp directly into the PA system in any way?
Does the noise change or go away if you turn down the input levels on the amp?
Does the noise change or go away if your disconnect any inputs from the amp?
Does turning down the FX return and or changing the FX on the amp make the noise stop?
Jonathan Dignam
« Reply #2 on: October 06, 2019, 12:20:09 pm »
-Yes it is coming out of the amp.
-No it is not connected to a PA system
-When I adjust the input levels it usually does not change anything. It does get quieter if I turn the main down. If I turn it off then back on it will some times stop.
-The first half of my performance I use a wired mic and acoustic electric guitar. I will typically get the noise during this time. The second half I have RCA cables and a 1/4 line going to the wireless mic. I usually do not have the sound then.
-Sometimes the sound stops when I adjust the fx.
Mike Caldwell
  • Covington, Ohio
« Reply #3 on: October 06, 2019, 05:59:18 pm »
Do you get the noise when you disconnect everything from the amp and just have the amp turned on and the levels turned up as they normally are when your using it?
Jonathan Dignam
« Reply #4 on: October 06, 2019, 06:23:29 pm »
Yes I do. That is what is so confusing.
Mike Caldwell
  • Covington, Ohio
« Reply #5 on: October 06, 2019, 07:41:31 pm »
That's an internal amp circuit issue that's going to need board level repair.
To be honest the amp may not be worth what the repair cost would be.
Jonathan Dignam
« Reply #6 on: October 07, 2019, 05:08:14 am »
Thank you.
Page created in 0.028 seconds with 23 queries.
