Pages: 1 2 [3] 4 5 ... 8   Go Down
Author Topic: Avantis - A&H Completing the Trilogy: SQ, dLive, ???  (Read 6014 times)
Scott Slater
Re: A&H Completing the Trilogy: SQ, dLive, ???
« Reply #20 on: October 04, 2019, 01:12:06 pm »
Wow!  This sure is looking interesting....  A&H updated their front page again.
Dave Garoutte
  • San Rafael, CA
« Reply #21 on: October 04, 2019, 01:33:25 pm »
So far the sneak peeks have looked like renderings, not photos.
Inventor.
Jonathan Goodall
  • New Zealand
« Reply #22 on: October 06, 2019, 09:20:41 pm »
Well, it's Oct 7th here......... waiting........
Peter Morris
Jonathan Goodall
  • New Zealand
« Reply #24 on: October 07, 2019, 05:34:52 am »
$19999AUD, bit more than the GLD.
$6999AUD For the GX4816.
« Last Edit: October 07, 2019, 05:54:26 am by Jonathan Goodall »
Jonathan Goodall
  • New Zealand
« Reply #25 on: October 07, 2019, 05:49:57 am »
I would like to see 12 FX engines, and 12 Dyn8 processors added to this new console.  They don't want to step on the toes of potential dLive sales, but at the same time this new console also needs to stand above the SQ series which has already set a pretty high standard.
Close, 12 FX and 16 Dyn8 (when you add the dpack) if I read it correctly.
« Last Edit: October 08, 2019, 04:58:42 am by Jonathan Goodall »
Roland Clarke
« Reply #26 on: October 07, 2019, 05:53:47 am »
Better looking form factor.
Scott Slater
« Reply #27 on: October 07, 2019, 08:03:18 am »
It's kind of like A&H meets Digico's S series.
Scott Slater
« Reply #28 on: October 07, 2019, 08:05:28 am »
IIRC the GLD + AR2412 listed at around $14,000US when it first came out.
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #29 on: October 07, 2019, 08:27:59 am »
Main features:
12FX
16 Dyn8
64 inputs
42 configurable busses
DiGiCo S21/S31 competitor, but way better IMO since the UI has much more physical buttons/controls.
Quote
All input channels shall contain the following processing:
Trim, Polarity, High Pass Filter, Low Pass Filter, two Insert
points, Gate, Parametric EQ, Compressor and Delay.
All output mix channels shall contain the following
processing: External input, Polarity, Trim, Insert, Parametric
EQ, and Graphic EQ with RTA and fader-flip mode,
Quote
96kHz 64 channel / 42 bus digital mixer
XCVI FPGA core with ultra-low latency (0.7ms)
Fully configurable mix bus architecture
Super-tough, full metal chassis
Continuity UI seamlessly connects physical and touchscreen controls for the fastest, most intuitive workflows
dPack option adds dLive processing, including 16 Dyn8 engines, plus per-channel zero-latency DEEP Compressors and Dual-Stage Valve preamp
12 RackExtra FX slots with dedicated stereo returns
16 DCAs
Dual 15.6” Full HD capacitive touchscreens with gesture control
AMM (Automatic Mic Mixer) up to 64 channels across 1, 2 or 4 zones
Fully assignable layout
144 fader strips (24 faders, 6 layers) with optional dedicated master section
SLink port for connection to Remote I/O Expanders and the ME Personal Mixing System
12 analogue XLR Inputs / 12 analogue XLR Outputs
1 Stereo AES In / 2 Stereo AES Out
2 I/O Ports, both capable of 128x128 operation at 96kHz – for optional cards inc. Dante, MADI and gigaACE
User configurable rotary controls
24 assignable SoftKeys
Comprehensive metering with multi-point peak detection
USB stereo recording and playback
BNC Word Clock
« Last Edit: October 07, 2019, 08:34:38 am by Nathan Riddle »
Pages: 1 2 [3] 4 5 ... 8   Go Up
Page created in 0.034 seconds with 24 queries.
