Author Topic: Amp with High and Low Pass for Danley THMini  (Read 591 times)
Wayne Smith2
« on: September 22, 2019, 03:39:57 pm »
I'm interested in downsizing / simplifying a bit to make my humble rig a little more efficient.  QU is the mixer now so unlike previously it can cover the needs when I don't take the Mini out.
Are there are recommendations for good 'one box solutions to pair with the THMini? Or also perhaps two non-powered  EV ZX-3s if that's not too much of a jump?
I want to add I guess I could perhaps sell the EV ZX-3s and pick up a second Yamaha DSR12 (..one was purchased for our smaller 'easy setup gigs) But would I be correct to presume that would be a sideways move?
Thanks
Wayne
« Last Edit: September 22, 2019, 03:54:23 pm by Wayne Smith2 »
Caleb Dueck
Re: Amp with High and Low Pass for Danley THMini
« Reply #1 on: September 22, 2019, 06:45:36 pm »
Thanks
Wayne
Are you asking for a DSP amp to power/process speakers and sub?
Or a speaker that is full range for gigs that don't need a sub?
Powersoft T series are great for inexpensive but not 'cheap' DSP amps, Danley DNA amps for larger systems.
Danley SM100F is a great little speaker that doesn't need a sub.
Wayne Smith2
« Reply #2 on: September 22, 2019, 07:02:35 pm »
I see where I could have been clearer. 'One amplifier solution'.
Thanks
Bob Stone
« Reply #3 on: September 22, 2019, 08:26:35 pm »
Would a PLD4.5 do the job?
Wayne Smith2
« Reply #4 on: September 23, 2019, 08:57:55 pm »
Thanks
That was the one line I was aware of, seems to have the needed feature set, costs are reasonable. I like that you can run a bridged and dual mono pairs. (Didn't look real deeply into them but didn't see those options on the Powersoft.
The THMini is rated 700w and EVs 600w continuous. I'm not sure if the PLD 4.3 be a good fit these speakers, or perhaps go for the extra headroom. I don't expect to ever push this rig to their max BTW.
edit to add the helpful links.. :>)
https://www.electrovoice.com/binary/ZX3-90_Engineering_Data_Sheet.PDF
https://www.danleysoundlabs.com/wp-content/uploads/2014/06/TH-Mini-spec-sheet.pdf
« Last Edit: September 23, 2019, 09:18:03 pm by Wayne Smith2 »
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #5 on: September 24, 2019, 08:00:21 am »
Powersoft T-series would be my go-to for this. Bit more power than the QSC PLDs, and 1U instead of 2.
Chris
www.grimshawaudio.com
Bob Stone
« Reply #6 on: September 24, 2019, 09:46:41 am »
Headroom is your friend, especially with subs...you can always turn it down, but can't turn it up if you need more than you have. Also, buying the 4.5 would theoretically let you run a second THMini plus the EV tops all on the single amp if you so chose down the road.
Page created in 0.026 seconds with 22 queries.
