Author Topic: Shure PA821 doubts  (Read 404 times)
Gian Luca Cavalliini
    • Live on Stage
Shure PA821 doubts
« on: September 11, 2019, 06:42:19 am »
Hi all,
1) is the passive combiner with frontal connection usable independently of the active part without any secondary problem?
2) The same passive combiner is reversable? (i mean could be used as a passive splitter? DC block?)
2) Specs say max input level is +24dBm each channel. What about output signal level? I mean: ch1 +17dBm and ch2 +14dBm remain exactly the same in the combined output?
3) If not 8ch are in use, using not adiacent ch can provide any vantage in isolation and maybe IMD?
4) providing +17dBm (50mW) every input, what is the 3th, 5th,7th order IMD level in the output?
as usually, sorry for my bad english
Thanx
Short coffee, SHORT coffee, more SHORT coffee... yes, I'm from Italy!
MikeHarris
Re: Shure PA821 doubts
« Reply #1 on: September 11, 2019, 07:34:29 am »
Using with PSM1000 ?
Combiner not distributor
    • Live on Stage
« Reply #2 on: September 11, 2019, 09:19:44 am »
Hi Mike, for what I know front comb (A - B - AB sum) is passive. Usually purely passive comb can be used in reverse as passive splitter. But I'm not shure if this is the case. I'd like to know, sometimes could be useful for additional antenna split for receving systems... :-)
Henry Cohen
  • Westchester Co., NY, USA
« Reply #3 on: September 11, 2019, 09:50:46 pm »
It's a completely separate, passive, circuit. Simply in the same rack frame for convenience.
Quote
Yes, being passive it's bi-directional. This circuit will not pass DC,
Quote
This is a unity gain stage; meaning whatever RF level is input for a given frequency, that's the level that will be at the output, independent of other input levels, circuit variances of +/- 2dB notwithstanding.
Quote
Yes, if there are less than 8 feeds, not using adjacent ports is recommended to reduce potention IM. Adjacent ports with active inputs should have the greatest frequency separation possible. If you take the input frequencies in ascending value, connect to combiner ports 1, 5, 3, 7, 2, 6, 4, 8.
Quote
I seem to recall the unit is rated for -70dBc (though it's not published). Thus the 2TX 3rd IM would be at -53dBm, 5th at about -59dBm, 7th at about -68dBm.
Quote
No worse than some of the native English speakers . . . on both sides of the pond, and in both hemispheres.
Henry Cohen
    • Live on Stage
« Reply #4 on: September 12, 2019, 03:04:13 am »
Henry, thanx.
If you come to Italy call me, free good wine and food for you. Beer and coffee is not enough
Grateful Gian Luca (Luke)  :)
Page created in 0.074 seconds with 25 queries.
