Author Topic: 2018 Mac Mini & Dante  (Read 6417 times)
Graham Spice
Re: 2018 Mac Mini & Dante
« Reply #10 on: September 05, 2019, 02:24:58 PM »
Philip - you were having an issue with a Mac Mini and Dante using the standard Ethernet port. Did you investigate an external chassis with a Danta PCI card or are you using an Ethernet dongle from another port? I'm considering purchasing a new Mini to use with Dante and could use some more feedback from you on this.
Thanks!
Did some more testing today. Verified the network settings mentioned in the post Robert linked to no effect. Also checked dropping from 64x64 all the way down to 2x2 as referenced in the Audinate FAQ linked by Andrew and still didn't get clock sync.
Contacted Audinate and got the following:
Oh well,
Thanks
Philip
Philip Roberts
  • Church and H.O.W. Forums
  • South West MI
« Reply #11 on: September 05, 2019, 04:33:07 PM »
I havenít tried the Dante PCIe card. We used person Ethernet to USB-C adapters to test but havenít purchased any yet. The old computers still work and I only have so many hours in the day.
Itís also possible that the base 1G port works and the 10G like I have doesnít even when running at only 1G
Philip
Scott Alan Thompson
« Reply #12 on: January 03, 2020, 09:49:51 PM »
Philip
Hey Philip,
I have the exact same issue with a 10G port Mac Mini 10.14.6. All second MBP 10.13.6 sync fine. Mini sees network traffic but fails to sync the clock.
Have you found a solution or do you know if a new Mini with a standard 1G port works?
I normally use Waves SG drivers but had an instance to use DVS. I have yet to use WSG so I am now leary of this platform.
Thank you in advance.
Philip Roberts
  • South West MI
« Reply #13 on: January 04, 2020, 10:07:01 AM »
We purchased USB-C to ethernet adapters and I haven't had time to check the new version of DVS on the internal interface.
Philip
ranjansriram
« Reply #14 on: March 29, 2020, 02:01:03 AM »
Has anyone one had success or failure using the 2018 Mac Mini with Dante? I've puchased a pair with the built in 10G interface for my church and we can't get Dante going. I've not been the lead in trouble shooting but the person who is seems to have narrowed it down to PTP sync signals not getting though. AES 67 didn't work but AVB did. Dante did work on an USB-C adapter.
Any ideas or troubleshooting suggestions?
Thanks
This is a known issue with the new Mac mini 10g NICs.
Audinate says they are working on a fix for it .
Ranjan
Harald Herz
« Reply #15 on: December 05, 2020, 09:44:15 AM »
Ranjan
Is there a solution to the Mac mini 10Gbps port issue yet?
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #16 on: December 05, 2020, 01:32:16 PM »
admin
Harald Herz
« Reply #17 on: July 01, 2021, 09:27:58 AM »
Apparantly not yet... but the latest version of DVS (4.1.2.3. from 2021-04-21) shows in the changelog, that this is a known issue. There it says;
"SODA-972: The built-in Apple 10GbE network interface causes multiple leader clocks. Awaiting fix plan from Apple."
(Source: https://my.audinate.com/content/dante-virtual-soundcard-v4123-macos
¬ę Reply #17 on: July 01, 2021, 09:27:58 AM ¬Ľ
Page created in 0.215 seconds with 24 queries.
