Author Topic: Make It A Double: Inside Approaches To Parallel Signal Processing  (Read 3953 times)
M. Erik Matlock
  • Global Moderator
  • Senior Editor Live Sound International/ProSoundWeb
    • M. Erik Matlock on PSW
Parallel processing, by definition, splits a signal and processes the copies separately, but there’s a sinister concern called "latency."
By Michael Lawrence • August 12, 2019
One of the earliest studio mixing tricks that I learned was parallel processing – running the same signal through several mixer channels and processing them independently. There are a few variants of this technique, the most common being parallel compression.
For example, the first application I saw of this was when a studio engineer double-patched a dynamic vocalist and compressed one of the channels. It gave the control of a compressed vocal but also helped to preserve the dynamics and “life” of the uncompressed signal.
Nerd Note: Electronically speaking, this is sort of the “opposite” of a standard compressor. A common compressor is downward-acting, meaning it reduces the signal’s dynamic range by lowering the louder moments. This parallel technique flips that around...
Continue reading here: https://www.prosoundweb.com/channels/live-sound/make-it-a-double-inside-approaches-to-parallel-signal-processing/
Train the next generation. Success without a successor is ultimately failure. wywu.org
Page created in 0.024 seconds with 16 queries.
