Pages: 1 ... 16 17 [18] 19 20 ... 23   Go Down
Author Topic: Possible X32 firmware rumored. Your suggestions?  (Read 47721 times)
Alec Spence
  • Herts, UK
Re: Possible X32 firmware rumored. Your suggestions?
« Reply #170 on: November 09, 2019, 12:19:57 PM »
Other than the routing changes, what other features might we expect with V4?
A subtle overhaul to the GUI throughout, some kind of predictive text if typing in text, RTA now uses colour to highlight levels, support for the DP48.
I'd not heard about a full mixer backup/restore - would be nice, though.
Robert Lofgren
« Reply #171 on: November 09, 2019, 01:58:13 PM »
This will be on the actual mixer itself when fw 4.0 is released.
How do you perform a full mixer backup?
I can't seem to find that option in m-edit 4.0.
Robert Lofgren
« Reply #172 on: November 13, 2019, 09:35:53 AM »
V4 of the firmware and editor is now up for download.
Release notes:
4.00 (2019-11-13):
  new features:
  - point to point user routing, 4 input and 6 output banks (32 in / 48 out)
  - DP48/HUB4 remote configuration support
  - DP48 setup page with preset library
  - send pan optionally follows LR pan function
  - full backup export/restore function
  - new keyboard with channel name suggestions/history and keyboard layouts
  - X32Core/M32C: Export Show function
  - M32/M32R: V.1 Fader option (forces update of faderboards, requires reboot)
  - option for coloured RTA bars
  improvements:
  - new GUI design
  - updated channel icons
  - coloured fader tracks
  - error/warning popups can be closed using encoders
  - popup option to perform backup before firmware update
  - Channel
      - Config: Low Cut filter curve preview
      - Config/Sends: Dynamic signal flow display
      - EQ: hiding unsettable parameters
      - Utility: copied channel overview
  - Meters
      - channel color indicators
  - Routing
      - tabs re-organized and grouped by function
      - output patch overview tables with shortcut to assign output
      - next button also scolls destination list
      - iQ setup: improved lists behaviour
  - Library
      - scrolling using LOAD encoder offers suitable presets only
  - Effects
      - warning message when creating feedback loop (only when using hardware encoders)
      - Utility: FX rack re-organized by effect category
      - Utility: copied effect preview
      - going from effect to library selects active FX slot
  - Setup
      - Config: more default bus configurations (all pre/all post)
      - Name/Icon: more channel name suggestions
  - Monitor
      - Talkback: destination preview
      - Lamp setting moved to new tab in Monitor screens (when available)
  - Scenes
      - Cues: cue number 500.9.9 is possible now
      - Snippets/Safes: select header to select all elements in column
  - Mute Groups
      - buttons made more visible on screen
Taylor Hall
« Reply #173 on: November 13, 2019, 09:56:57 AM »
Guess I know what I'm doing after work tonight!
1) Do it right
Robert Lofgren
« Reply #174 on: November 13, 2019, 10:12:20 AM »
Going to the pub to get some beer and pizza?
John L Nobile
« Reply #175 on: November 13, 2019, 10:13:50 AM »
I never trust new firmware or software releases. Been burnt a few times.
Is rolling back to an older version an option with these boards?
Robert Lofgren
« Reply #176 on: November 13, 2019, 10:24:57 AM »
Rolling back is a non-issue. I’ve done it literally hundreds of times.
 Make sure to backup your scenes to be on the safe side. Under some circumstances the power-on snapshot may be reset so make sure to save a snapshot before updating if you intend to keep it. NOTE, this does not affect the saved snapshots/scenes, only the power-on snapshot.
Riley Casey
  • Wash DC
« Reply #177 on: November 13, 2019, 10:39:01 AM »
Got a link ? Nothing of the sort is showing up on the X32 page or the support page at Behringer.com.
« Last Edit: November 13, 2019, 11:08:39 AM by Riley Casey »
Chrysander 'C.R.' Young
  • North Central FL
« Reply #178 on: November 13, 2019, 11:00:59 AM »
Got a link ? Nothing of the sort is showing up on the X32 page of the support page at Behringer.com.
http://downloads.music-group.com/software/behringer/X32/X32_Firmware_4.0.zip
Riley Casey
  • Wash DC
« Reply #179 on: November 13, 2019, 11:13:27 AM »
Thanks, How about links to the editors Mac and PC ?  music-group.com loads to a blank page with a 503 error.  Are these some sort of guinea pig pre-release perhaps?
Pages: 1 ... 16 17 [18] 19 20 ... 23   Go Up
Page created in 0.035 seconds with 24 queries.
