Pages: 1 ... 9 10 [11] 12 13 ... 23   Go Down
Author Topic: Possible X32 firmware rumored. Your suggestions?  (Read 13539 times)
Robert Lofgren
Re: Possible X32 firmware rumored. Your suggestions?
« Reply #100 on: September 17, 2019, 01:33:49 am »
I knew that Iíd asked the devs this x32 reverb Q before and it was in the late-2016  8)
Quote
Actually the one that comes close to the VSS3 structure is the EMT, with different parameters though, that is called DVR2 in Reverb4000/6000.
Most of the other reverbs are based on a Lexicon style structure.
VSS style reverbs with lots of early reflections are currently not available on the X32 due to memory bandwidth limitations when using four of them.
Roland Clarke
« Reply #101 on: September 17, 2019, 05:05:26 am »
The problem might be down to both horsepower and the dsp engine they are using.  I believe the Heritage uses three dsp systems to deal with different aspects of the console system.  FPGA is great for mixing engines as itís fast, but I believe this is much more difficult for programming reverbs and effects.  Depending on what the X32 has inside, there maybe limitations to what level of fx complexity may be programmed.
Geert Friedhof
« Reply #102 on: September 18, 2019, 06:04:13 am »
Actually an M3000 and D2 sims would be awesome. There needs to be a simpler, more basic delay in the X32. I don't want stereo, ping ponging, phasing, chorusing delays. Just a simple delay with tap. Mono output, 15-20% feedback, adjustable hi and lo cuts. Thats it.
Actually what I'd love to have is an old fashioned analog bucket-brigade delay.
The current delay does all that, and can be easily set to mono. I use the assignables for tap, feedback and factor. I don't need a d2. A decent reverb however would be nice.
John A Chiara
« Reply #103 on: September 18, 2019, 11:15:27 am »
Iíve had best luck with the Quantec Ďmodelí highly modified.
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #104 on: September 18, 2019, 12:09:33 pm »
I know it "can" and I have, certainly. But the built in delay's starting presets are too crazy for a basic mono slap. And if I haven't set it up before the gig, I don't want to fiddle with it while the band is playing. It's too much to tweak on the fly.
On a standalone D2 you just dial up "Straight 2290 Delay" and there you go.
Robert Lofgren
« Reply #105 on: September 18, 2019, 12:17:31 pm »
Why donít you create your own fx preset in the fx library?
Tim Weaver
« Reply #106 on: September 18, 2019, 12:41:07 pm »
Thats just too easy. I want behringer to code an entire new delay unit for me.
« Reply #107 on: September 18, 2019, 01:19:38 pm »
Rolls my eyes!
Taylor Hall
« Reply #108 on: September 18, 2019, 03:23:52 pm »
1) Do it right
John A Chiara
« Reply #109 on: September 19, 2019, 12:35:37 am »
ĎToo much to tweak on the fly?í
Really? I reassemble FX all the time while the show is going on..
You can set up a preset.
¬ę Reply #109 on: September 19, 2019, 12:35:37 am ¬Ľ
Pages: 1 ... 9 10 [11] 12 13 ... 23   Go Up
Page created in 0.041 seconds with 24 queries.
