Author Topic: How to sync SR300 with SM100  (Read 1112 times)
Dave Guilford
« on: August 01, 2019, 01:42:05 pm »
How do I sync these 2 units?
Sennheiser sr300 A band
Sennheiser sm100 A band
Both show same freq on screen (518.200).  I see the SR300 receiving input, but nothing on the SM100.
What am I missing?
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
Re: How to sync SR300 with SM100
« Reply #1 on: August 01, 2019, 02:27:27 pm »
I think I remember having to do something with a pilot tone? Maybe tell the receiver to not look for it? Someone likely remembers the detail. I am old 😳
What am I missing?
John Sulek
  • Toronto Canada
« Reply #2 on: August 01, 2019, 02:33:14 pm »
What am I missing?
Have you defeated the pilot tone squelch on the receiving device? Which I'm assuming is an SK 100? My bad...thinking of the wrong end.
You should put the transmitter in mono mode as well.
« Last Edit: August 01, 2019, 05:28:49 pm by John Sulek »
Dave Guilford
« Reply #3 on: August 01, 2019, 04:38:07 pm »
 Yes and thank you guys! I had to turn off the pilot Tone
What is a pilot Toney? And why would it be on? Any reason that I would need to turn it back on ever?
John Sulek
  • Toronto Canada
« Reply #4 on: August 01, 2019, 05:27:30 pm »
Pilot tone is a sub or supra sonic tone transmitted along with the "normal" rf signal.
Pilot tone tells the squelch circuit on the receiver to open which allows audio output.
This helps prevent bursts of noise on the audio out of the receiver caused by unwanted rf signals that are strong and close enough in frequency, but not from the intended transmitter.
Think of it as a keyed noise gate.
This is a very simplistic explanation but hopefully conveys the idea.
Shure's "Selection and Operation of Wireless Microphone Systems" by Tim Vear is a great primer for all these topics. On their website.
It is enabled by default on most devices because disabling it in casual use can cause more problems than it solves for the less experienced.
You probably want to turn it back on if you stop using this gear for point to point applications.
Dave Guilford
« Reply #5 on: August 01, 2019, 07:33:29 pm »
Super. That makes sense and I get it.  Presumably my sr300 doesn’t send a pilot tone, so the sm100 will never work with pilot activated.  Yes?
Russell Ault
  • Edmonton, AB
« Reply #6 on: August 02, 2019, 01:27:19 am »
Close; strictly speaking the SR300 does send a pilot tone, but not in mono mode (and I believe even in stereo mode it's a different pilot tone than the EW 100 receivers use).
Since sending the wrong the pilot tone is as useful as sending no pilot tone, either way the rest of what you said about the the RX not working while it's expecting a pilot tone and not getting one is spot on.
-Russ
Page created in 0.05 seconds with 24 queries.
