Author Topic: EAW SB1000z drivers  (Read 7209 times)
Helge A Bentsen
  • Oslo, Norway.
EAW SB1000z drivers
« on: July 29, 2019, 06:10:21 pm »
I bought 4 SB1000z for cheap last year and I'm planning a paint job and new drivers for them.
I know what the original drivers are, I can buy them from my local dealer.
However, I replaced the 12" in some KF750 boxes with a lightweight NEO driver and it turned out pretty well. So this got me thinking, is there another driver that can perform well in a SB1000z and maybe shave off a few kgs?
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
Re: EAW SB1000z drivers
« Reply #1 on: July 30, 2019, 04:16:47 am »
I'd do some physical measurements of the cabinet, load those into Hornresp, and try a few drivers. Keep an eye on port velocity if you're simulating high-power drivers - the SB1000z doesn't seem to be intended for those.
Chris
www.grimshawaudio.com
Art Welter
« Reply #2 on: August 02, 2019, 04:24:38 pm »
Chris
Chris,
The SB1000z uses both a large center slot port between the slanted baffles and ducted ports on the upper L/R of the front baffle. Although the smaller ports may have high velocity at high power, they will also create a chimney effect reducing internal cabinet heating, reducing power compression.
Many high power/excursion Neo magnet drivers could probably outperform the OEM drivers without port velocity (chuffing) issues.
B&C 18NBX100,18NW100, 18SW100, 18SW115 would all "get er done" and lighten the truck load.
Art
Peter Morris
« Reply #3 on: August 12, 2019, 05:43:06 am »
My best GUESS is that the SB1000z used 18sound 18WL1400's, and before the Z version RCF 18P300's  - if that's correct, then it should be easy to find a better neo version of the 1400, hopfully some can confirm if I'm right or wrong.
Peter's 2c
Helge A Bentsen
  • Oslo, Norway.
« Reply #4 on: August 13, 2019, 02:10:09 pm »
Peter's 2c
They are indeed 18LW1400 in the "Z" version.
I upgraded some "E" versions to "Z" a few years ago and EAW shipped the drivers in 18LW1400 boxes with a EAW sticker on the driver.
Matthew Knischewsky
« Reply #5 on: August 21, 2019, 12:28:02 pm »
Helge, do you mind sharing what 12" driver you went with for the 750s? how much weight was reduced?
Those original McCauley 12s are difficult to find cone kits for.
Helge A Bentsen
  • Oslo, Norway.
« Reply #6 on: August 22, 2019, 11:13:56 am »
I used B&C 12NDL88.
They are a bit too deep, so you have to put in a shim when mounting them som the magnet doesn't hit the cabinet floor. They are half the weight of the 12LW1400 that replaced the McCauley drivers. I saved 12kgs per KF750.
Matthew Knischewsky
« Reply #7 on: August 24, 2019, 05:14:33 pm »
I used B&C 12NDL88.
Thanks for that info ! That's a fair weight savings.
Page created in 0.041 seconds with 22 queries.
