Author Topic: Acoustic guitar into Senn Beltpack Transmitter  (Read 1050 times)
frank kayser
« on: June 12, 2019, 02:49:47 pm »
Hi again,
Coming from the wired world, I'm used to using a DI box to interface the acoustic guitar (as an example) to the board.  Passive DI for active pickups, and active DI for passive (e.g., K&K) pickups is the general rule of thumb.
One thing I'm aware of is that the passive K&K and the like, need something with very high input impedance so as not to lose the bottom end of the instrument.  Something like a Baggs Paracoustic, or Radial Piezo work well.
So...
I know plugging a active pickup into the Senn (and others) beltpack with the appropriate cord is no issue, but how does one handle a passive pickup?  Does the beltpack offer high enough impedance on its own?  Plug it in downstream of an active DI (battery, self powered, of course)?
Ho do you work with this?
frank
Ike Zimbel
    • Zimbel Audio Productions
Re: Acoustic guitar into Senn Beltpack Transmitter
« Reply #1 on: June 12, 2019, 03:40:22 pm »
Hi again,
So...
frank
I would just go ahead and try it. I haven't noticed any issues in the past, and, the pack is the functional equivalent of an active DI (in that it has an electronic input rather than a transformer). You would need to check specs to see the actual input impedance. Also, if you scroll through the menus, some systems have "cable emulation" which try to mimic...wait for it...cables (and their loading effect on a pick up).
One thing you do need to be aware of is that if the pack is digital, it may induce all sorts of unwanted noise into the pick-up.
~Ike Zimbel~
Wireless frequency coordination specialist.
Radio Active Designs
~416-720-0887~
Russell Ault
  • Edmonton, AB
« Reply #2 on: June 12, 2019, 05:06:33 pm »
According to the spec sheet, the SK 100 G3 has a line input impedance of 1 MΩ, which really ought to do it.
-Russ
Tim Hite
    • Bad Quail
« Reply #3 on: June 12, 2019, 08:18:19 pm »
K&K Maes these, seems like the hot ticket. . .
https://kksound.com/products/purexlrpreamp.php#simple2
Bad Quail
Sound + Light
Joshua Tree, California
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #4 on: June 12, 2019, 09:54:39 pm »
i've plugged my K&K into several different wireless systems with no issue.  Granted, none of those have been the Senn, but i wouldn't expect any problem.
brian maddox
bdmaudio@gmail.com
Mike Caldwell
  • Covington, Ohio
« Reply #5 on: June 13, 2019, 08:47:51 am »
The later Sennheiser wireless packs have a guitar cable emulation mode.
Scott Helmke
« Reply #6 on: June 13, 2019, 10:17:52 pm »
Doesn't that *lower* the impedance to simulate a guitar amp input?
Russell Ault
  • Edmonton, AB
« Reply #7 on: June 13, 2019, 10:55:07 pm »
Sounds like it's mostly a capacitance change (if anything, using a longer cable should result in a higher impedance, unless I'm missing something).
-Russ
Mike Caldwell
  • Covington, Ohio
« Reply #8 on: June 14, 2019, 09:19:21 am »
It changes the input capacitance, not sure what the range of adjustment is, never used that function.
Another "feature" for guitar players, the Sennheiser receivers have a built in guitar tuner. I wonder how many people actually use it.
frank kayser
« Reply #9 on: June 14, 2019, 07:24:30 pm »
-Russ
Thanks, Russ, for the spec.  I hate to admit, but the capacitance change vs cable length is a bit above my pay grade...
Good point.  Trying it is easier said than done.  I have a K&K on my box, but it's hard-wired into a K&K Pure Preamp (pre 2015).  Facing one "in the wild" seems to happen only a couple times/year.  Digital introducing noise?  Hmmm... Something to look out for.
Well, it seems unanimous.  Not a worry. Senn. Shure. AT. Lectrosonics.  They probably all function very similarly.
Count on one hand? I can't see that being any of the following - quick, easy, or convenient.  Tough to beat a clip-on tuner...
Thanks everyone,
frank
Page created in 0.068 seconds with 20 queries.
