Author Topic: Routing to use 2 mics into DBR speakers  (Read 775 times)
jesseweiss
« on: June 09, 2019, 12:39:32 pm »
Our DBR10s only have one xlr input with mic/line settings. The 2nd xlr input is labeled Line only, and isnt sensitive enough to get good gain with a mic. If we wanted to use 2 mics without setting up our mixer, could we loop the Thru output from each speaker to the other? So mic into input 1 on each speaker, then Thru out to input 2 on the other.
It seems like it would work theoretically,  but I'm worried there are issues I'm not aware that could cause problems.
Mike Caldwell
  • Covington, Ohio
Re: Routing to use 2 mics into DBR speakers
« Reply #1 on: June 09, 2019, 01:39:33 pm »
What are these mic going to be used for?
I could see the speaker looping idea possibly creating a feedback loop between the speakers.
Could you just combine the two mics, a Y cable will work with dynamic mics, best to use the same model of mic.
To do it "right" Whirlwind makes a transformer based mic combiner.
I have seen some small passive mic mixers, can't remember the make and model right now.
Keith Finch
« Reply #2 on: June 09, 2019, 01:45:31 pm »
jesseweiss
« Reply #3 on: June 09, 2019, 02:43:49 pm »
Vocals at practice and that's what I was worried about, feedback.
I may have some y cables,  but didn't even think of a small mixer/pre like in the other post. I'll look around online.
Thanks!
Eric Snodgrass
« Reply #4 on: June 09, 2019, 03:59:41 pm »
Low cost and No Power needed
http://www.artproaudio.com/product/dual-rdb/
Off-Topic -
Take a look at the pictures Art Pro Audio uses for this item on their website.  It's a used piece of gear with the lettering scrapped off in places.  It's also dusty.
One would think that they had a new item to use for the pictures.
Chris Grimshaw
  • Sheffield, UK
    • Grimshaw Audio
« Reply #5 on: June 09, 2019, 05:21:10 pm »
The idea you had will work. You can route Ch1 input to the XLR output.
A better option, IMO, is to simply have a speaker per mic.
Chris
www.grimshawaudio.com
Mike Caldwell
  • Covington, Ohio
« Reply #6 on: June 09, 2019, 08:04:57 pm »
Off-Topic -
That is kind of bad!
I've seen a couple pieces of equipment on manufactures websites that were missing screws. It's like they took the proto type to photo studio.
jesseweiss
« Reply #7 on: June 10, 2019, 12:16:22 pm »
Chris
That works, but it means that each mic output is louder depending on which speaker one is closer to.
It's for a weird situation where my band practices with middle school kids for an event we run and we aren't all in the path of both speakers.
Brian Adams
    • Adams Production Services
« Reply #8 on: June 10, 2019, 01:41:52 pm »
Most product "photos" these days aren't photos at all, but very realistic renderings. Sometimes the product hasn't even had a prototype yet, at least not one that you'd want people to see. At least ART is showing you what the actual product looks like, I guess.
Brian Adams
Vermillion, SD
adamsproductionservices.com
Steve Garris
« Reply #9 on: June 10, 2019, 02:11:59 pm »
I carry one of these in my toolbox. It works really well.
https://www.avlifesavers.com/xlrmixm.htm
Page created in 0.082 seconds with 24 queries.
