Author Topic: Sub-$500 Passive Monitor Suggestions  (Read 1420 times)
Augustine Ortiz
« on: May 30, 2019, 01:43:11 pm »
Are Yamaha Club Series (SM12V/SM15V/CM12V/CM15V) still kind of the king of budget passive stage monitors?  Is there something better out there?  Maybe EV, Peavey?
This would be for a portable system and a 1 man weekend warrior situation.  Mainly for rougher non-staged floor environments where active stage monitors would take too much of a beating.  And I already have the power-amps, cables etc.  Just my current passive stage monitors have taken quite a beating, smell like spilled beer, and it is time to get something better.
Bob Faulkner
  • Raleigh, NC
Re: Sub-$500 Passive Monitor Suggestions
« Reply #1 on: May 30, 2019, 02:00:46 pm »
I use 8 of the CM12V powered with 2 x QSC PLD-4.2.  Have had the speakers (new) for about 6 years. They've been great; sound good, and can take some of the bumps/thumps of people moving them around.  I questioned their build quality when I first received them (in another post), but they have worked.  They are used for the smaller fairs/festivals with everything from a 16 piece band down to a duet.  All the performers have said they sounded good and were plenty loud (I always ask - want to make sure they are happy with my service as well.)
Also - the CM12V looks a lot more professional than the SM12V (which I had for years before moving to the CM12V).  I removed the Yamaha plastic plate from the grill... the cabinet looks good and non-descript.
« Last Edit: May 30, 2019, 02:03:15 pm by Bob Faulkner »
Steve Litscher
    • MixMasters Podcast
« Reply #2 on: May 30, 2019, 02:10:25 pm »
+1 for CM12V
We had six of them before upgrading to DSR112 (active). The CM12V worked really well, and never gave us any problems. They sound decent, too.
Kevin_Tisdall
  • Milford, CT
« Reply #3 on: May 30, 2019, 02:24:39 pm »
I had a mix of 8 of the SM12IV and V speakers and they worked fine for a long time until I wanted to get into powered wedges.  Then I went to the dsr112's and never looked back.  If you have all the other stuff to run them they are fine.
--Kevin
Luke Geis
« Reply #4 on: May 30, 2019, 02:25:46 pm »
I would go with the JBL PRX-412M before I went with the Yamaha Club stuff. The PRX isn't a huge jump up, but it is probably the best you can get for $500.
JBL PRX-PRX412M Pro's:
1. It is lined with a Rhino Liner type of product.
2. It is quite lightweight @ 35lbs.
3. It handles a good amount of power @ 1,200 watts peak.
4. Can double as a main PA speaker with no issues at all.
5. I have worked with them before and they sound pretty darn good. They are not the loudest speaker there is, but they sound decent.
JBL PRX-412M Con's:
1. Not very loud with a peak SPL of 126db. Should be plenty loud for monitors though.
2. A little bulky in dimensions, but the monitor angle is good though and gets the speakers pointed at your head.
3. It's an 8-ohm box, so extrapolating volume out of it does require reasonable power needing 600 watts at 8-ohms from your amplifier.
4. It uses a 1" HF driver, but its a pretty good one. The same one used in the VRX if I'm not mistaken.
Yamaha Club V Pro's:
1. Uses a 2" HF driver. Not much to go with here, some people care, some don't; the JBL's 2414 used in the PRX is a very good driver at this price point.
2. Hey, the Club series has been around since the 70-80's or something like that! They will be around for quite a bit longer too.
3. They sound ok, but nothing to call home about.
4. They don't require a huge amp to get volume out of them. 350 watts @ 8-ohm's from your amp will get you what you can get from them.
Yamaha Club V Con's:
1. They are carpet covered........ Yup still using Rat Fur in the modern era.
2. No cover over the massive horn. If beer is commonplace for your stage, it won't take long till your Club V gets drunk.
3. Not very loud at all ( neither is the JBL though ). The specs say it has a sensitivity of 97db @ 1 watt 1meter. This means that at 700 watts ( peak power ) it is capable of a whooping 124.8db peak SPL. Which means that it has a continuous output around 119.4db. The JBL has a continuous SPL of 120. It does make good noise with little power though, needing half what the JBL does to do it.
4. Not as good sounding as the PRX if you ask me. This is an entry level speaker and it sounds like it. The JBL is at least one tier up in the JBL offering.
To further draw a comparison among other models. For $500 you won't get a Rhino Lined product from other vendors. EV is the best bang for the buck, but they will be plastic and or painted wood. QSC is all self-powered and plastic. If they aren't plastic or painted wood, it will be Rat Fur. JBL is probably the only company I know of that has a Rhino Lined product that performs well and sounds decent for that price point.
Don T. Williams
    • Q Systems Music & Sound
« Reply #5 on: May 30, 2019, 04:50:15 pm »
A sound company we partner with uses the db Technologies Arena 12's (and a couple of the 15's)  These sound consistently good. Very little EQ (if any) is needed to get the vocals sounding very good.  It has a plywood cabinet with textured paint, and open cell foam over the steel grill, so they look very nice.  They are worth a look.
Michael Storey
  • San Jose, CA
« Reply #6 on: May 30, 2019, 06:27:29 pm »
I'll add the Turbosound TMS122M to the list. They sound good, look good, and are very well built. You should be able to get them in your budget (from some of the dealers that participate on this forum).
One major con- the distributor always seems to be out of stock. I do have two more coming to me now, so if you order soon you should be in luck.
Tim Hite
    • Bad Quail
« Reply #7 on: May 30, 2019, 06:28:33 pm »
You can get Clair SRM's in clamshell flight case for $1000/pair.
Can get you close to your budget with Turbosound TFM122M showing 52 in stock
Bad Quail
Sound + Light
Joshua Tree, California
Patrick Cognitore
« Reply #8 on: May 30, 2019, 07:20:19 pm »
If I were in your shoes I'd be eyeing the used market. Multiple times I've seen various models of EAW SM and LA series wedges pop up for under $500 (sometimes well under).
Might even keep an eye our for larger production houses selling off their old (but professional and functional) stock as they upgrade.
Steve Litscher
« Reply #9 on: May 30, 2019, 07:41:24 pm »
Couple of clarifications:
1) The CM12V has an epoxy coating; the SM12V have carpet
2) The CM12V has a full, foam lined grille that covers the horn.
3) With a PLD4.5 powering them with DSP controls, ours got nice and loud - good enough for busy, loud stages at outdoor festivals.
I agree they aren’t going to compete with TT+, Clair, or db technologies, but they are decent enough. With some careful shopping, you can get a pair for just under $600...
« Last Edit: May 31, 2019, 11:04:28 am by Steve Litscher »
