Author Topic: Hopefully I'm doing things the right way  (Read 2198 times)
Josh Larrimore
« on: May 17, 2019, 02:46:47 pm »
Hi everyone,
This is my first post here after lurking for a bitwhat a great community. I hope to gather some feedback on my setup so I can make things efficient and sound good for all of my gigs.
Background:
I'm the bass player in a four piece rock band with electronic drum set. We do local inside and outside gigs for crowds of up to about 200 people. I handle all the sound. I'm also a DIY home audio guy and build speakers and crossovers in my spare time ... hence me ending up with the sound guy role, which I really enjoy. On top of our gigs, we also offer our services to run sound for other local bands and team up with local charities and music schools to put on school of rock type events.
Our gear:
Alesis Studio 32 mixer
Rane DA316a power distribution
Behringer DSP2024P for effects (mostly compression and reverb ... not the prettiest)
(2) Crown XTi 2000 (one for PA, one for subwoofers)
Crown Ultra-Tech 1010 (for monitors)
DIY breakout panel for amp outputs to speakers (so I don't have to go into the back of the box)
Everything is installed in one rolling rack, including the mixer board (picture attached)
All speaker connections are Speakon.
A plethora of mic stands, cables, a 16-channel snake I want to try to use to mix from FOH instead of besides the stage so I can friggin' hear what I'm doing during sound check, and SM57 (drums/instruments) and SM58 (vocals) mics.
Speakers:
(2) Carvin 1562 speakers
(2) Sound Bridge 3118SW subwoofers
(4) JBL 15" monitors
I've been able to get things sounding okay ... but we always strive to improve. On top of my basic setup techniques of getting gains set correctly and such, is there anything I'm doing that doesn't seem like the best way to go about things? I'm sending my effects out via Aux Send and Aux Return and mix in the amount of effect I want with the Return mix slider on that channel. I have up to two separate monitor mixes I can send to each channel of the monitor amp (Crown), which we sometimes do to give our drummer a different mix than the rest of us (since he's on a electronic kit).
Eventually we'll be upgrading the Alesis mixer to a newer analog Yamaha 16 channel board (at least it'll be set up for live sound and not studio) and then a Behringer X32 which we should be getting within a year from another sound company that's upgrading.
I also really want to upgrade the Behringer effects board to something nicer that I can throw reverb and compression on at the same time, which doesn't seem like I can do right now with it. It doesn't seem very flexible and I'm not happy with the quality of the effects. Hopefully something under $2-300.
When we play outside, I feel our lower octaves slouch thanks to the cheap Sound Bridge subs, so I was thinking of building a pair of Bill Fitzmaurice folded horn subwoofers to fill that gap. On top of that, the single horn-loaded tweeter in the Carvin PA speakers (with double 15" drivers) can cause some horizontal off-axis nastiness as I walk around left to right outside. I'd love to be able to make a modular stand-based line array (no flying here) that I can adjust per expected audience size, but I think that's a ways out.
So there's some things to improve on ... what do you guys think? We're obviously pretty budget-minded as you can tell from our existing gear. Much of this has been donated via charities and friends to the group.
Will Knight
Re: Hopefully I'm doing things the right way
« Reply #1 on: May 17, 2019, 02:48:31 pm »
Please go back to your profile and change your user name to your real first and last name as required by forums rules that were given to you when you signed up or your post will be locked by the moderators
Roland Clarke
« Reply #2 on: May 17, 2019, 04:16:03 pm »
Hi Josh,  Im not familiarity Bills horn subs, but I would urge you to look at some of the other options available to the DIY community. Art Welter Keystone subs have good performance and are relatively an easy build.  There are several good tapped horns including the th18, and the Othorn as well as various Cubo designs, but these are trickier to build.  There are some decent ported subs on the 18 sound website.  These may suit your need better, particularly if you want more deep bass.
Steve Litscher
    • MixMasters Podcast
« Reply #3 on: May 17, 2019, 05:50:49 pm »
I can appreciate the enthusiasm as well as what youre doing with this gear and the limited budget.
That said, Id strongly urge you to follow the buy once, cry once mantra and not invest any money in the temporary Yamaha digital board or another outboard effects unit, especially if youre close to buying an X32.
The X32 will be money well spent. Then, Id forego building your own subs, unless you have a lot of experience with woodworking and have a solid set of plans... youll spend nearly as much building some as you would buying a decent set of used subs, like say some decent JBL 2x18s or similar. And youll have better future resale when/if you decide to upgrade to something else.
Lastly, you may want to consider selling the amps and going with some decent active speakers. Some Yamaha DXR12 would be a major step up, and would offer additional versatility, and again, better resale in the future.
Just my $0.02
Caleb Dueck
« Reply #4 on: May 17, 2019, 07:12:48 pm »
Just my $0.02
Wise advice.  Anything that is temporary/band-aid is a fancy way of saying - waste of money.
DIY anything now days, unless you have experience and really want to focus on the learning aspect - typically falls into this category, or easily can.
Subs - fewer, higher quality/output subs are better than more lower-end subs.  A single JTR Captivator 218 (for example) is worth considering over a pair of basic single 18" subs. If you need more - you add one more, rather than starting with 2 and then adding 6.
What I would do - outline the real system you need, keeping your time in mind.  Likely X32, a great subwoofer, and a pair of good speakers.  Then find the most direct path to those and bypass the waste rabbit trails.
Paul G. OBrien
« Reply #5 on: May 17, 2019, 07:44:10 pm »
I'd also advise against both of these moves, if you're going spend money go straight to a digital board now even if that means a rack version like the X32R or even a XR18 or similar. You get so much processing with any of these digital mixers it's makes no sense at all to be buying outboard processing or another analog board.
Yeah that is the problem this speaker design, a 15" really should not be allowed to operate above about 800hz as it's output pattern narrows too much and a 1" exit CD can't operate that low so the compromize is a crossover up around 2khz. That leaves a big section of the critical vocal range with very poor off axis support and in your case there isn't an easy fix as there isn't enough room in those Carvin boxes to substitute a larger 2" exit CD, so you probably need to plan for a wholesale FOH upgrade at some point.
I am a DIY fan but I think you should probably limit that to subs, your plan to build a line array is pretty much guaranteed to fail.. there is so much more involved in getting true line array performance than just a stack of boxes, it will get very complicated and expensive very quickly.
Options to improve your FOH would include passive mains with 2" exit CD's and/or 3-way boxes, but to get the most out of those will require more amp channels and some DSP processing so also consider powered cabs like the JBL SRX800 series. Here again you are looking at a quantum leap so to speak similar to what a digital mixer provides, there is so much going on inside these speakers you simply could not match the performance with the same money spent on passive speakers and outboard processing and amplification.
« Last Edit: May 17, 2019, 07:58:17 pm by Paul G. OBrien »
Luke Geis
« Reply #6 on: May 17, 2019, 09:27:52 pm »
I further support the advice given. Building your own speakers is very much a labor of love. Unless you are a pretty damn good physicist, pretty darn good with wood-working and don't mind spending nearly the same price for your " project " as you would a commercial unit, it is very much a fruitless endeavor.
These days, baby steps don't really pave the way as it may seem in other industries. If you can afford it, buying the best that you can buy gets you many steps ahead, both in terms of sales and ease of use. Most bands don't like hearing the word " homemade " and most ( not all, but truly most ) homemade units are not easy to run without lots of work and determination. If you buy a higher end speaker, it pretty much runs itself and you spend more time enjoying the job ( as does your clients ) and you get more rewarding results. Same goes for mixers. If you plan on going to a digital format, don't wait on the premise that you still need to learn or that it's the next step in evolution from where you're at. The market has adjusted well and affordable digital mixers are extremely valuable to advancing your place in the sound world. If you can run an analog mixer at all, a digital one, while not fun to learn on while at show, is easy enough to grasp and learn quickly.
My final suggestion is to rely heavily on self-powered speakers. While they do cost a little bit more than a passive counterpart, they are cheaper in the long run and really do make your life easier. Most are getting so good that even a cheap unit is better than most of the best stuff you could buy 20 years ago. The pond is getting rather shallow these days and spending just a little bit more money, can really get you from having stuff that is just meh, to having stuff that really does perform well. That price point to me exists at around the $700 mark. If you buy a powered speaker that costs roughly $700, you are getting a pretty darn good unit. Scale that to the used market where you can get that same speaker for nearly half, you can see how saving a few bucks more really ups your game significantly.
To close this up. Buy Once Cry Once is a real thing in this industry. You do get what you pay for in this industry. If you want to wallow at the bottom of the pond that is fine but don't say we didn't try to get you floating nearer the surface. Buy what you really want, and sell everything you don't need.
« Reply #7 on: May 17, 2019, 09:45:09 pm »
"Buy once, cry once."
"The wrong product at the right price is still the wrong product."
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #8 on: May 18, 2019, 02:02:13 pm »
It's been said in all the above posts, but I'll throw this out there. Since you are a home speaker builder you'll get the gist of what I'm saying. Bill FitzM designs are the "bose" of the diy world. All hat and no cattle.
DIY is still a lot of fun if you are into it, but like everbody has mentioned, it doesn't save you money anymore. The name brand products are so cheap and so good that you can't build something better anymore. The Yamaha DSR112 is a wonder of product design.
Google these two names: Art Welter and Peter Morris. These guys design some serious, SERIOUS gear that you can build at home. Peter M's stuff isn't cheap to build, but what you end up with will blow away anything you might buy second hand from a soundco. Art has designed some reasonably priced subs and some more expensive stuff too. All of it will destroy what you have now.
Seriously, look into the X-air18 for your rig. It's cheap, will fit into your amp rack, and will offer comps and gates on every channel plus 4 FX units that are worlds better than what you are using now. It's exactly half of the X32.
Good luck.....
Rick Powell
« Reply #9 on: May 18, 2019, 04:45:15 pm »
Unless you are shooting for the stars, Peter Morris' PM 60 and PM 90 designs are definitely not entry level. The parts will probably cost $1500 per cabinet, and he uses an expensive processor, the Lake LM26, for each speaker to get the most out of it. And it requires 3 powered amp channels per speaker to run them 3-way.
Art Welter's Keystone sub, Josh Ricci's Othorn, and "xoc1" TH18 plans can all be found at diyaudio Subwoofer forum and would all cost less than $1000 per cabinet, but as mentioned only the Keystone is a relatively easy build. Having the correct speaker also goes a long way; the models that work best (like the B&C 18SW115) are often in the $500 apiece range. Throwing "any old speaker" in there won't yield the best results, and they have tested and simulated the models that work best.
I agree with other posters here that the new powered stuff is a no-brainer for most applications. The newer stuff like Yamaha's DSR series and JBL's SRX800p series uses Finite Impulse Response (FIR) filters to correct for phase and EQ anomalies and make for a very intelligible and even response through the speaker's pattern which would be difficult to duplicate DIY, unless you want to spend thousands going the "Peter Morris" route. I also agree, cut directly to the chase, don't trade up sideways to get to your goal; an interim solution is more trouble than it's worth. Figure out what you really need and go figure a way to get it.
« Last Edit: May 18, 2019, 04:47:40 pm by Rick Powell »
Page created in 0.066 seconds with 25 queries.
