Author Topic: change a 4 pin DMX connector to a 3 pin DMX connector  (Read 606 times)
Jesus Ortiz
« on: May 10, 2019, 05:47:31 pm »
I just bought 12 RGB luminaires for the external part of a building, but the came with a 4 pin DMX connector and all the DMX512 I found accept a 3 Pin Dmx connector, I need to change the connector but I didn't know what cable  to eliminate or how to connect it, need your advise
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #1 on: May 10, 2019, 06:07:38 pm »
need your advise
admin
John Fruits
Re: change a 4 pin DMX connector to a 3 pin DMX connector
« Reply #2 on: May 11, 2019, 05:20:51 am »
What brand of fixtures and model?  Generally in DMX controlled lights with the 4 pin XLR it is using what is known as color scroller cable.  It uses a cable with a shielded twisted pair for the DMX signal plus a twisted pair for power.  One example is the City Theatrical unit for Color Kinetics.
http://www.citytheatrical.com/products/750-trx-pds
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Jeff Lelko
  • Cape Canaveral, FL
« Reply #3 on: May 11, 2019, 03:02:27 pm »
...but they came with a 4 pin DMX connector...
Before saying that you need to adapt these to 3 pin you need to determine why they use 4 pin.  As John already mentioned, 4 pin usually involves power transmission and isn't interchangeable like 3 pin vs 5 pin DMX usually is.  You almost always need to use driver box that merges a power supply and any incoming DMX command signal.
Page created in 0.027 seconds with 22 queries.
