Author Topic: Midas Mr18 TCP ports  (Read 1295 times)
Gary Fitzpatrick
  • Fermanagh, Ireland
« on: May 08, 2019, 12:03:50 pm »
I'm installing a midas Mr18 in a church soon, and I'm wondering what TCP ports does the Mr18 use to communicate with the apps?
I'm thinking of setting it up so I can remote access the mixer
Sent from my EML-L09 using Tapatalk
Allen Heath GL2000, EV sx300 over Community pro Subs, EV s-200 monitors, Zeck amplification
Chrysander 'C.R.' Young
  • North Central FL
Re: Midas Mr18 TCP ports
« Reply #1 on: May 08, 2019, 05:51:39 pm »
Access the mixer remotely?  From where?  Why?
I can tell you that every time someone has asked me this question, upon further analysis, my answer was "This is a really bad idea."  I am curious if you will be the exception.
Gary Fitzpatrick
« Reply #2 on: May 09, 2019, 12:22:34 am »
I will be installing this system in a simple style Catholic church. It is a set and forget type system. Only a few mics running through it, but ocassionaly you get the phone call "can you turn the altar mic up a small bit". It would allow me to make minor adjustments off site. Not an essiental use but if it could be done it would be nice.
There is also an Axis P1357 camera installed for live streaming the services so I have remote viewing and listening capabilities also in that church.
« Reply #3 on: May 09, 2019, 12:57:05 am »
Use a VPN for security.
Cailen Waddell
« Reply #4 on: May 09, 2019, 07:43:22 am »
I’m not an IT expert - but I’ve always thought a local machine with team viewer or something and a strong password is a better option for situations like this...
Caleb Dueck
« Reply #5 on: May 09, 2019, 08:49:33 am »
The real answer is - don't use a bar band, hands-on style mixer when a DSP (QSys, Xilica, Tisera, etc) style mixer is what works best.  Add a Domotz box and you're set.
Magnus Högkvist
« Reply #6 on: May 09, 2019, 12:07:43 pm »
Because MR18 is so hands on....
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #7 on: May 09, 2019, 08:56:23 pm »
This is the simplest and easiest solution IMHO.
That being said, i have used a VPN to access an X32 from across the country directly and it worked fine.  All i needed to do was have a VPN established [we used a Cisco Meraki Cloud VPN Network] and then just use the standard X32 software to control the mixer.  I don't see any reason why the same could not be done with an XR18.
brian maddox
bdmaudio@gmail.com
« Reply #8 on: May 10, 2019, 01:59:32 am »
The problem with Teamviewer and other remote access software is they require a host PC and often human intervention between sessions.
A VPN on the other hand runs on the router and won't lock up.
Gary Fitzpatrick
« Reply #9 on: May 10, 2019, 03:19:50 am »
In the past I would have used BSS soundwebs in churches. They have a few more bells and whistles, but the MR18 does pretty much everything I need it to. It has more inputs and outputs and is quicker to set up.
Page created in 0.035 seconds with 24 queries.
