Author Topic: S6L stand alone editor software  (Read 609 times)
Harry Brill Jr.
« on: April 27, 2019, 04:31:43 pm »
I have been trying to install 6.0 and 6.1 versions of the stand alone software.  I just get errors.  I have tried this on 3 64 bit windows 10 machines, 1 a VM, 1 Bootcamp, and 1 is essentially a Waves Extreme server running windows 10 pro 64 bit, so gigabyte system board, 4790K CPU.  All have had more than enough resolution, but this is not a running issue, its an installation problem.  The software will not install.  No installer ever opens.  If you double click the .exe it just throws an error.  I have re-downloaded several times as well.  Anyone else having, or had this issue?
Justice C. Bigler
  • back home in Oklahoma
    • My homepage
Re: S6L stand alone editor software
« Reply #1 on: April 27, 2019, 05:39:03 pm »
I Harry, how you doin'?
Have you contacted Avid? I hear they have an outstanding support system, as long as your support subscription is paid up.
I didn't have any trouble installing the Venue software on my Windows 10 Laptop. And I just checked it again and it seems to run fine. But I'm not running a virtual machine, so I assume that's probably the likely culprit. Although Avid says that you should be able to install it via VM or Parallels.
Justice C. Bigler
www.justicebigler.com
Phillip Ivan Pietruschka
« Reply #2 on: April 27, 2019, 07:59:12 pm »
No specific experience; but having you tried ‘Run as administrator’ that has sorted out a number of apparently weird problems with installers and applications for me. As long as you trust the software that is...
Kevin Maxwell
« Reply #3 on: April 27, 2019, 11:08:30 pm »
Could it be the screen resolution problem? The Screen resolution of your monitor must be at least 1920 x 1080 or the standalone won't open.
Ray Soly
« Reply #4 on: April 28, 2019, 01:42:17 pm »
nevermind,
Ray
« Last Edit: April 28, 2019, 06:31:57 pm by Ray Soly »
Andrew Broughton
    • Check Check One Two
« Reply #5 on: April 28, 2019, 04:05:02 pm »
-Andy
Page created in 0.046 seconds with 23 queries.
