Pages: 1 [2] 3  All   Go Down
Author Topic: Next-level EQ  (Read 1473 times)
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
Re: Next-level EQ
« Reply #10 on: April 17, 2019, 12:12:27 pm »
- Better singers with better technique
Put brutally, no amount of EQ and effects will polish a turd.
I agree with this. Was the first thing I thought. Should have stated that.
Based upon Isaac's equipment list and assuming the integrator did a decent job.
I think that mixing skill or singer skill or both that are lacking.
Miguel Dahl
Re: Next-level EQ
« Reply #11 on: April 17, 2019, 01:11:10 pm »
The best way I learned how to do EQ / understand frequencies was to do a lot of panels/speeches and such. It's just one voice at a time to focus on, and you can hear what you're doing very easy. After a while you'll learn to distinguish frequencies from instruments/voices in a full band setting. And don't be afraid to just cut everything, or boost something, play and experiment. What you hear is what you hear. If it sounds good it's most often good.
duane massey
Re: Next-level EQ
« Reply #12 on: April 17, 2019, 02:18:42 pm »
++1000 on mic technique. It HAS to start here.
Duane Massey
Houston, Texas
Eric Snodgrass
Re: Next-level EQ
« Reply #13 on: April 17, 2019, 05:27:54 pm »
The older I get the more I've found out that using differently voiced microphones (and from different manufacturers) is a huge step towards achieving a good mix.  The more eclectic the microphone collection used the easier it is to separate the instruments and vocals in the mix AND the less EQ one needs to use.  Using the same two or three microphone brands/models on stage for music makes it harder to get separation in the mix.
Next-level EQ?  Learn how different microphones sound different from one another.  Learn to use those different microphones in your sonic palette.
Dave Garoutte
  • San Rafael, CA
Re: Next-level EQ
« Reply #14 on: April 17, 2019, 07:37:02 pm »
Different mics was my first thought, but the OP mentioned wireless, so unless they are willing to go wired, there aren't a lot of choices.
Inventor.
Tim Hite
    • Bad Quail
Re: Next-level EQ
« Reply #15 on: April 18, 2019, 12:59:43 am »
It's easy enough to screw on a new capsule to your wireless. Shure makes a reasonably priced SM86 wireless capsule RPW114 amongst others.
Bad Quail
Sound + Light
Joshua Tree, California
Tim Hite
    • Bad Quail
Re: Next-level EQ
« Reply #16 on: April 18, 2019, 01:01:15 am »
++1001?
Mic technique is everything. Garbage in > garbage out.
Bad Quail
Sound + Light
Matthias McCready
Re: Next-level EQ
« Reply #17 on: April 18, 2019, 02:16:17 am »
Additionally, Sound Tools offer some wireless adapters which allow the use of Sennheiser, Neumann, and Audix capsules with the Shure transmitters.
Lyle Williams
Re: Next-level EQ
« Reply #18 on: April 18, 2019, 04:16:02 am »
Record a multitrack on the mixer.
Fiddle and experiment to your hearts content afterwards.
Matthias McCready
Re: Next-level EQ
« Reply #19 on: April 18, 2019, 11:44:13 am »
Being able to multitrack is one of the best learning investments a church can make. This is a valuable tool, both for engineers to learn and hone the craft or to do a better mixdown before service.
 It also is great for working with the band, so that they can listen and critique their own parts.
Re: Next-level EQ
Pages: 1 [2] 3  All   Go Up
Page created in 0.089 seconds with 23 queries.
