Pages: 1 [2] 3  All   Go Down
Author Topic: New Arrayable Trap Boxes?  (Read 2305 times)
Steve Ferreira
Re: New Arrayable Trap Boxes?
« Reply #10 on: April 01, 2019, 04:01:20 pm »
I know that L'Acoustic has the ARCs.  Are there any other higher-end manufacturers making arrayable boxes?
Meyer JM1Ps
RCF TTL6 might work as well for this application.
Lower end of things JBL SRX 835p?
Doug Fowler
  • Saint Louis, MO USA
« Reply #11 on: April 01, 2019, 04:04:46 pm »
Sorry I didn't make it clear in my original post.  This will not be a permanent install.  These will be used and flown on a per-event basis.  Portability and ease of rigging will be considerations.
SH-46 is very good.  Passive, plug and play, no DSP required for the most part.  Easy to rig with the right flybar, no chains, straps or guessing. Just tight pack and go.
Used:
X-Array
KF750 with focused processing
NEXO Alpha
db audiotechnik C4/C7
Turbosound
Don T. Williams
    • Q Systems Music & Sound
« Reply #12 on: April 01, 2019, 05:53:51 pm »
The trap boxes that array well together should provide good service, but with flying hardware and the weight of some most of those boxes, be extremely careful about flying these anywhere that people will be under them.  250 lbs.+ of speaker and lift falling on people can be fatal.  There are line array lifts that have a large V" truss type base from several truss manufacturers that look fairly safe, but they are not cheap.  Safety comes at a price, but being unsafe is really expensive!
Jeff Lelko
  • Cape Canaveral, FL
« Reply #13 on: April 01, 2019, 06:17:18 pm »
Just to ask the question since it hasnít come up yet, how much space are you trying to fill.  What SPLs are you trying to achieve, and whatís the budget?
The Danley J3 sounds great and is a one-box wonder, although rather large and heavy.  As already mentioned, at a smaller level the RCF TTL6a can do a neat trick of arraying 2 boxes vertically.  The Yorkville Synergy system looks interesting (I have yet to hear it), but it seems to be painfully expensive and limited for what it is and how it must be used.  Hope this helps!
  • Old enough to know better
  • Audio Plumber
« Reply #14 on: April 01, 2019, 06:27:26 pm »
These are pretty new...http://yorkville.com/synergy/
Looks like someone reinvented the MSL-10.  ;)
Karel Noon
« Reply #15 on: April 01, 2019, 11:41:34 pm »
http://www.axiomproaudio.com/
Check out that brand, high quality components, and a nice array able trap box the AX1012 that they launched some weeks ago.
Peter Morris
« Reply #16 on: April 02, 2019, 12:20:17 am »
Yeah, it does look like that  ;)... except to top synergy horn on the Yorkville can go down to 55Hz, then there is the tripple 15" sub enclosure mounted below it which is normally crossed at 100Hz to the horn on top.
Peter Morris
« Reply #17 on: April 02, 2019, 12:27:52 am »
.... I know that L'Acoustic has the ARCs.  Are there any other higher-end manufacturers making arrayable boxes?
RCF TTP 5-A - POINT SOURCE ARRAY
https://www.rcf.it/en_US/products/product-detail/ttp-5-a/234688
Meyer Sound JM-1P : Arrayable Loudspeaker
https://meyersound.com/product/jm-1p/
Uwe Riemer2
Andrea Litti
    • my FB page
« Reply #19 on: April 02, 2019, 07:26:50 am »
Rcf has the TTP5, a 15"+2" (4" vc) powered arrayable speaker, externally similar to LA's Arcs or some Meyer model I don't recall (the above mentioned Upq maybe?). There's also a forthcoming model called TTP4 with double 10" woofers and a 4" vc driver
EDIT: didn't see the above posts probably cause I was typing at the same time, sorry!
« Last Edit: April 02, 2019, 07:29:19 am by Andrea Litti »
¬ę Reply #19 on: April 02, 2019, 07:26:50 am ¬Ľ
Pages: 1 [2] 3  All   Go Up
Page created in 0.044 seconds with 25 queries.
