Author Topic: Allen & Heath Waves Card Question  (Read 527 times)
Sean Chen
    • Pristine Audio
« on: March 29, 2019, 06:55:44 pm »
The SQ WAVES CARD, when plugged into the I/O port of a SQ mixer, can I do multi-track recording and run WAVES plug-in simultaneously? Help much appreciated!
Pristine Audio
Authorized dealer for Allen & Heath, Countryman, Danley Sound Labs, Dynaudio, Electro-Voice, Gator Cases, HK Audio, K&M, Mackie, MiPro, RCF,  Yorkville
www.pristine-audio.com
MikeHarris
Re: Allen & Heath Waves Card Question
« Reply #1 on: March 30, 2019, 05:00:50 am »
Maybe a question for your rep...but I do know a recent dLive sale included both Waves and Dante..Dante for recording. I can ask later today
Matthias McCready
« Reply #2 on: March 30, 2019, 12:05:06 pm »
Yes, you can do this. Soundgrid can connect to multiple devices, I think it is at least 6-8. Theoretically, you could run it to a computer for Multitracking, a server and 2nd computer for plugins, and to other locations such as second waves enabled console for a broadcast desk. There are also bridges from waves to Dante or MADI.
Waves made a helpful chart.
Not sure about stability with a complex setup as I have only worked with simpler setups.
Hope that helps :-)
Michael Gazdziak
« Reply #3 on: March 30, 2019, 03:08:25 pm »
In the overview tab on this page:
https://www.waves.com/live-sound/allen-heath
it says you can only do "Simultaneous Recording & Processing" with SoundGrid configuration, which "uses a dedicated SoundGrid DSP Server to power the plugin processing."
Sean Chen
    • Pristine Audio
« Reply #4 on: March 30, 2019, 05:18:45 pm »
Thank you guys for the helpful info. So looks like native mode (without Sound Grid server) cannot process and record simultaneously. I will contact my rep as well.
Pristine Audio
Mark Oakley
    • Oakley Audio
« Reply #5 on: March 30, 2019, 06:26:15 pm »
I'm using an iLive with a Waves M2 card. "Native" mode simply means either recording or running plugins on a host PC with higher latency, but not both. With a Soundgrid server you can record and process plugins simultaneously.
-Mark
Page created in 0.047 seconds with 24 queries.
