Author Topic: Help with zero88 Flx s24  (Read 334 times)
Gary Fitzpatrick
  • Fermanagh, Ireland
« on: March 29, 2019, 05:35:37 pm »
I know this is probably a silly question.
So I got a zero88 Flx S24. I had it set up last night with 4 Showtec Phantom 3R beams. I programmed a few different fx on to the playbacks. Everything worked fine, but when I dropped the playback the light went back to home with every attribute. I was wondering is it possible to set it that when you drop the playback the dimmer drops to zero and the lights just stop where they are instead of returning to home?
Sent from my EML-L09 using Tapatalk
Allen Heath GL2000, EV sx300 over Community pro Subs, EV s-200 monitors, Zeck amplification
Mark Cadwallader
  • Helena, Montana USA
Re: Help with zero88 Flx s24
« Reply #1 on: March 29, 2019, 06:41:50 pm »
Probably. Your next cue is not to stop playback, but to have your dimmer intensity go to "0" (or whatever that attribute is call on your fixture). Everything else remains the same from a programming standpoint.
John Fruits
« Reply #2 on: March 30, 2019, 11:27:10 am »
You might also consider asking this question at a couple of other places.
There is the UK based forum BlueRoom
The forums at Zero88
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Page created in 0.066 seconds with 23 queries.
