Author Topic: Audio Cable and Ethernet Cable continuity tester recommendations  (Read 1431 times)
Dan Richardson
  • southern Vermont
    • NotTooLoud
Re: Audio Cable and Ethernet Cable continuity tester recommendations
« Reply #10 on: March 30, 2019, 09:44:10 am »
This one's not in the same class as the Fluke, obv, but it's a good leg up from most of the cheap ethernet testers.
Triplett / Byte Brothers CTX200
The $100 kit includes a sniffer.
https://www.amazon.com/gp/product/B003ZK4Q02/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
The best sound system is no sound system. Everything else is compromise.
Ray Soly
« Reply #11 on: March 30, 2019, 07:21:10 pm »
Weve been using the dBX CT-3 and so far we dig it! Hard to tell from the pic, but its actually two physical units bolted to a plate that can be separated to work at either ends of an installed cable.
https://dbxpro.com/en/products/ct-3
Another vote for the CT3
Ray
Mike Caldwell
  • Covington, Ohio
« Reply #12 on: March 30, 2019, 08:44:40 pm »
And it will test "speaker twist" connections!
« Last Edit: March 31, 2019, 10:32:18 am by Mike Caldwell »
Eric Snodgrass
« Reply #13 on: March 31, 2019, 10:26:14 am »
And it will "speaker twist" connections!
What do you mean by "speaker twist"?
Mike Caldwell
  • Covington, Ohio
« Reply #14 on: March 31, 2019, 10:45:05 am »
I meant to say 'And it will test "speaker twist" connections!"
In the CT-3 info and on the actual unit they call what we all know as a Speakon a "Speaker Twist" connector.
Maybe it has to do with trade mark infringement so they could not use the word "Speakon" on the tester.
Nathan Riddle
  • Niceville, FL
    • Nailed Productions
« Reply #15 on: March 31, 2019, 11:08:39 am »
I really like my Signaltek NT for testing Ethernet cables.
They have a different method of ensuring cable integrity than the other testers. Not quite certification, but it ensures the line can handle gigabit by sending data.
http://metroconnect.blogspot.com/2008/03/choosing-qualification-tester_07.html?m=1
Tim Hite
    • Bad Quail
« Reply #16 on: March 31, 2019, 11:01:08 pm »
Do you suppose Harman elected to use knock off connectors in their unit and had to forego using the SpeakON name?
Pretty sure that if they'd used an actual Neutrik, it would be fair use to mention it's included in the product.
Bad Quail
Sound + Light
Joshua Tree, California
Mike Caldwell
  • Covington, Ohio
« Reply #17 on: March 31, 2019, 11:23:38 pm »
Look at the side pictures of the CT3, you can tell the connectors are a knock off.
Page created in 0.074 seconds with 24 queries.
