Author Topic: Church Sound: Top Ten Worship Audio Line Check Problems  (Read 379 times)
M. Erik Matlock
  • Global Moderator
  • Senior Editor Live Sound International/ProSoundWeb
    • M. Erik Matlock on PSW
« on: March 25, 2019, 08:16:01 am »
Do you know how to handle problems when they arise during sound check?
By Chris Huff • March 25, 2019
Do you panic when you don’t get a signal from the stage? “Why can’t I hear the singer!?!”
No more worries…this list explains the common line check problems and how you can fix them, meaning less time spent on line checks and more time making the band sound great!
Doesn’t that sound better than “oh no, what do I do?”
1. Bad Cable
Cables goes bad and if you don’t test your cables on a regular basis, then the issue will most likely show up during a line check. Or, worse, during the service!
A standard issue cable tester can tell you when a cable has gone bad and the issue with the cable.  Keep spare cables of all types because you will need them. On a related note, having the right tools like a line tester helps a lot...
Continue reading here: https://www.prosoundweb.com/channels/church/church-sound-top-ten-worship-audio-line-check-problems/
Train the next generation. Success without a successor is ultimately failure. wywu.org
Page created in 0.045 seconds with 24 queries.
