Author Topic: Single ear mic recomendation please?  (Read 844 times)
Ken Webster
« on: February 25, 2019, 05:44:11 pm »
Hi,
Our pastor uses a single ear mic something like this:
Brand name is something like Macarden (I don't have the spec sheet with me right now).
It was a relatively inexpensive option purchased from a PA supplier.  The 1st one broke because the pastor tried bending it to what he thought would be a better fit.  The current one has developed what sounds like a make break contact fault (when he waves his arms about) except mic sound is never lost.  I did wrap some tape around where the lead joins the mic which seemed to stop the noise for a couple of months but it's become noisy again.   I realise these things are delicate and need careful handling.  However I would like recommendations as to a replacement that might be a bit more robust please.
Regards,
Ken
« Last Edit: February 25, 2019, 10:41:38 pm by Ken Webster »
Brook Hovland
    • DiA Events
Re: Single ear mic recomendation please?
« Reply #1 on: February 25, 2019, 06:00:11 pm »
Hi Ken,
Avlex makes a decent Countryman E6 copy but it will not be as robust as the real thing.
I would look at the offerings from Countryman, Shure and DPA.
FWIW double ear units are as comfortable and require less bending than the single ear units
Again...  cry once!
« Reply #2 on: February 26, 2019, 07:55:23 pm »
Hi Ken,
Again...  cry once!
The price will stun you but the DPA d:fine is the class leader.  Once you use one you won't go back.
River Delta Audio is now:
Kevin Maxwell
« Reply #3 on: February 27, 2019, 08:37:20 am »
I keep hearing from others that the DPA earset mic is so great but I recently heard at a church (before and after) where they changed to them for the speaking and I wasn't impressed. With that sound system all the flaws showed up worse then before. So just changing out a mic isn't necessarily going to be a cure all.
My complaint with all headset mics is they are usually too long for normal human beings. The capsule gets in front of the mouth because of this and you have all sorts of problems. I think the Countryman mics started this and I think he designed them for his head. A lot of the mics can be custom ordered at a shorted length but they should come stock in shorted lengths and by shorter I mean so on a normal head the capsule should land almost an inch back from the side of the mouth.
The type of mics like what I have seen like the DPA where the boom is adjustable is a nice feature. And for most churches that use these types of mics they are a better choice. But the design makes it a little bit more bulky then a plain old Countryman E6 and for a musical I can get away with an E6 most of the time, for the people I work with, but the sliding boom under the ear type wouldn't be acceptable.
Tim Hite
    • Bad Quail
« Reply #4 on: February 27, 2019, 04:54:32 pm »
Kevin, I've ever had an issue fitting a Countryman E6 to an adult. There's a lot of length adjustment that can be done using the process in this video:
https://www.youtube.com/watch?time_continue=65&v=llEVIskkiXQ
As for the OP, Countryman would be the go to and DPA on the high end. You can email me for a quote if you need.
Bad Quail
Sound + Light
Joshua Tree, California
Kevin Maxwell
« Reply #5 on: February 27, 2019, 11:31:23 pm »
She says "aim for a quarter size spot just back from your mouth when you are smiling" and then she smiles and the mic capsule is at the corner of her mouth, not back from the corner of her mouth. The technique she is demonstrating doesn't shorten the length of these mics. I have seen that video before and I stick by everything I have said. I like Countryman mics and I would love to swap all of the ones that we have for the custom shorter version. But the cost would be prohibitive for us.
I am constantly having a problem with the actors breath noises in the mics. I have taken to at times using a particular lesser quality mic (that has just recently been discontinued by the manufacturer) because it is shorter.
I have too much experience with these mics and it is very frustrating because they are too long for the actors that we use them on. These are people with normal size heads. I have seen people bend the boom into a Z trying to get the capsule to sit back where it should. I think that looks too stupid to do that but I have done just about everything else to make them sit far enough back from the mouth and the nose.
BTW my other complaint is for some usages I would like it if is there was an optional cable available between the standard 1mm and the optional 2mm. The 1mm is too thin and the 2mm is too thick. How about a 1.5mm cable.
MikeHarris
« Reply #6 on: February 28, 2019, 06:14:04 am »
The most successful headset mic our customers like is the Que Audio DA12DE.
Hands down the most comfortable...if the pastor won't wear it or feel confident it matters not how good it sounds. The version our clients like was initially sold as 'childs' now called 'petite' and while only offered in omni it's shorter length and closer proximity make it usable in 85% of applications.
Ken Webster
« Reply #7 on: March 03, 2019, 02:35:15 am »
Thanks for the recommendations, I have left some options with the Pastor and await his decision.
In the mean time I have done a sort of repair.  Not a real repair as the the wiring is too fine and right at the point the lead exits the earpiece.  The fault is still there.  I would have liked to shore it up with heat shrink but the size needed to pass over the 5mm mic and slip down to the break would not shrink tightly enough onto the lead to prevent movement at the fault.  Instead, I built up successive layers of SeamGrip glue to reinforce the lead and taper off its flex to be over a reasonable radius and not at the single point of the fault.  If I force it, it will still pop but we used the mic today without any negative issues at all.  So for now it looks to be a successful fix.  It turned out pretty neat and unobtrusive if your wondering but I have had a lot of practice with this sort thing in other applications.
Still, I know the fault is lurking there and may show up again at any time, so I advised the Pastor that a replacement mic is needed as a fail-over strategy.
This Chinese mic is about  A$80 or US$57 so I figure, the economics of a more expensive mic seems uncertain so I am unsure which way to go on it and have left it up to him.
Ken
MikeHarris
« Reply #8 on: March 03, 2019, 05:12:34 am »
Ask your dealer to get you a Que demo.  We routinely supply @ 4 a year to visiting pastors who try it...love it..and wish to use it back home.
Mike Caldwell
  • Covington, Ohio
« Reply #9 on: March 03, 2019, 05:30:35 pm »
At your facility who is the keeper and handler of the microphones?
If not monitored and controlled a $600 headset will get just as  bent, broken, destroyed and lost as a $50 headset mic, at least until that happens the $600 mic will sound better!
One thing I don't like about mics like you pictured in your first post is the use of the long barrel adapters for different body packs. The long barrel puts a lot strain on the body pack connector when people lean over or sit on the body pack.
« Last Edit: March 04, 2019, 07:24:54 am by Mike Caldwell »
Page created in 0.047 seconds with 24 queries.
