Yikes, no! If you reverse polarity in this situation you'll short the output of the amp through the grounded side of the scope probe and the safety grounds on the scope and amplifier AC power connections. Hopefully the amp goes into shutdown before something lets out the magic smoke. That's why you gotta watch this.
Thanks. This is why I'm asking. Still learning about the design of some of these things. I had assumed that the output of the amp had a high "+" and low "-" side to the signal, not a signal and ground reference.
After many years of operating the system, I want to learn more about the why things work the way they do, and with a little help from you guys and some luck, learn without letting out the magic smoke.
