Author Topic: Speaker amp question  (Read 478 times)
Seth Thompson
« on: February 05, 2019, 08:11:57 pm »
In our foyer we have three Tannoy 4" CVS4 160 watt speakers fed by a single channel of a BiAmp MXA75 75 watt 6 channel mixer/amp.  We have 2 problems with this setup. The first is that it's never loud enough.  The second is that if we turn the amp up half way (6 out of 12), the amp will inevitably stop working and not work again until powered off and back on.  I do not know enough to say if we need more amp or more speakers.  I don't know if the amp is shutting off because it's trying to protect the speakers or if it's just failing.  Does anyone have any insight they can share?
Peter Tran
    • peterletran
Re: Speaker amp question
« Reply #1 on: February 08, 2019, 03:23:47 pm »
I'm not a professional by any means, but
there are several variables that need to be considered in this scenario:
1. Are the speakers wired with transformers
2a. If not with transformers are they wired in series or parallel (i.e. resistance/ohm reading)
2b. If with transformers (I can't help you because I am not familiar with voltage systems)
3. How large is the room?
4. Is this for ONLY speech or are you trying to play music through it?
Mike Caldwell
  • Covington, Ohio
« Reply #2 on: February 08, 2019, 07:28:38 pm »
What are the speaker wattage tap selectors set at and on the amps output terminal strip what terminal positions do you have the speaker line connected to.
Erik Jerde
« Reply #3 on: February 08, 2019, 11:27:16 pm »
Your “single channel” comment is confusing as this amp is mono output and by definition is only a single channel.  We need to know how the amp is wired and how the speakers are tapped.
Chris Grimshaw
    • Grimshaw Audio
« Reply #4 on: February 09, 2019, 10:31:08 am »
My bet is the amp is going thermal (or overcurrent) and shutting down.
Check wiring at both ends, and look at the amp to see if there's any dust/fluff/rubbish built up in there.
Chris
www.grimshawaudio.com
Ken Webster
« Reply #5 on: February 10, 2019, 05:01:04 am »
Found a PDF data sheet for the speaker:
Impedance 6 Ohm
Power:
40 W average
80 W program
160 W peak
Maximum SPL:
103 dB average
109 dB peak
Recommended amp 80 W into 6 Ohm
Mixer amp has 6 input channels.
MXA75
Output power, 4 ohms:  75W  RMS
Power consumption:  100W  Maximum
Weight:  8.6kg
Ken
« Last Edit: February 17, 2019, 04:12:41 am by Ken Webster »
Mike Caldwell
  • Covington, Ohio
« Reply #6 on: February 10, 2019, 10:58:43 am »
Chris
My thought as well as to why it's shutting down.
Most likely caused by wrong speaker tap settings and the wrong connection on the amp's output terminals.
My guess is the speakers are all set on the direct tap setting put somewhere around a 2 ohm load on the amp.
Ken Webster
« Reply #7 on: February 10, 2019, 03:36:14 pm »
I Deleted my post as too many erroneous and misleading assumption made.
Ken
« Last Edit: February 17, 2019, 04:14:01 am by Ken Webster »
Seth Thompson
« Reply #8 on: February 10, 2019, 04:06:55 pm »
Thanks for all the responses.
Here's a link to the electrical drawings they left with us, but when I look at them I can't tell if series or parallel.  https://drive.google.com/open?id=0B1vK_TvhbNg9ZjJjMDMxOTgtZDk2MS00OWIyLTk4OTctOWQwYWQwZmJkNDNi
I will try and do the "only one speaker" test soon.
We use it for both music and speaking and typically it will shut down during the music (much louder) and we can reset for the speaking and it stays on until music starts back.
I will blow out the dust on the amp before the service tonight and see if that helps too.
Erik Jerde
« Reply #9 on: February 10, 2019, 04:40:40 pm »
That drawing is useful.  It shows that the speakers should be being driven off of the 70v output of the amp.  This will be easy to confirm by just looking at the connections on the back of the amp.  Verify that positive is connected to the 70V terminal (second from left) and that negative is connected to com.
The speaker tap setting is accessed by pulling the grill.  If they are not all set to 30w/70v then start by getting that set and test.  If they are set to 30w then step them down to 15w and test.  That amp is not up to a 90w continuous load so if you’re really hitting it then tapping down the speakers may help.
Page created in 0.068 seconds with 21 queries.
