Best Kick Drum Mic?
Tim McCulloch:
--- Quote from: Kemper Watson on May 15, 2023, 06:55:24 PM ---How often does that happen?
--- End quote ---
The M-88"TG" was made in response to kick drum use. Same polar response, different diaphragm and suspension, IIRC.
How often will either submodel fail? Depends on the drummer/genre/placement. That a model was built to accommodate drum use kind of tells me Beyer didn't want to do warranty replacements at the then rate of failure. What is that rate? Dunno.
Kemper Watson:
--- Quote from: Tim McCulloch on May 22, 2023, 01:01:41 PM ---The M-88"TG" was made in response to kick drum use. Same polar response, different diaphragm and suspension, IIRC.
--- End quote ---
Mine is a TG. I'll use the windscreen. It's an amazing kick mic. Thank you Tim
Kemper Watson:
--- Quote from: Kemper Watson on May 23, 2023, 07:00:13 PM ---Mine is a TG. I'll use the windscreen. It's an amazing kick mic. Thank you Tim
--- End quote ---
Has anyone here tried the Beyer Boundary mic? I'm wondering if they might have learned from the 88 and make something that sounds the same and is a bit more sturdy?
John Schalk:
--- Quote from: Kemper Watson on June 25, 2023, 09:20:38 PM ---Has anyone here tried the Beyer Boundary mic? I'm wondering if they might have learned from the 88 and make something that sounds the same and is a bit more sturdy?
--- End quote ---
I use the Beyer TG-D71 boundary mic on kick drums and I like it. It's slightly more compact than a Beta 91. It sounds good and eliminates a mic stand and therefore the opportunity for a performer to knock the bass drum mic out of position. I use an Audix D6 when I can't use the Beyer.
Rob Stevens:
--- Quote from: John Schalk on June 26, 2023, 11:09:27 AM ---I use the Beyer TG-D71 boundary mic on kick drums and I like it. It's slightly more compact than a Beta 91. It sounds good and eliminates a mic stand and therefore the opportunity for a performer to knock the bass drum mic out of position. I use an Audix D6 when I can't use the Beyer.
--- End quote ---
I use one for exactly the same reason, its nice to eliminate the stand on some of the narrow stages we end up on, my back up is a D112.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
