Author Topic: program smart ups to shut down board recording?  (Read 569 times)
boburtz
  • San Francisco Bay Area
    • SoundWizard Productions
« on: February 02, 2019, 02:43:20 pm »
I'm thinking about a way to keep the usb recording on the QL5 from becoming unusable in the event of a power failure (or deliberate shutdown without stopping the recording). Has anyone used the gpi input for this purpose? There are many smart ups units that will safely shut down connected computers, I'm wondering if there is a way to program one to send a gpi message to stop the recording.
Erik Jerde
Re: program smart ups to shut down board recording?
« Reply #1 on: February 02, 2019, 02:59:24 pm »
Interfacing with UPSs can be tricky because mfgrs want you to buy their software so they donít usually document the interface very well (if at all).  Intrepid coders have done so though and thereís a pretty solid UPS daemon available for Linux computers now.
My angle would be to interface the UPS with a raspberry pi computer and then fire a gpio from that.  The built in gpio on the pi makes it great for these sorts of things.  Plus itís small so you can just throw it in the doghouse with a little Velcro and youíre good to go.  I run headless effectively embedded raspberry pis in a few places and they work great and are as bulletproof as the software I write for them.
Scott Helmke
« Reply #2 on: February 02, 2019, 03:56:56 pm »
I think you could do something as simple as a wall wart power supply producing a low DC voltage. When mains power drops the loss of that DC voltage could (I need some time to think about how) a GPIO input.
Andrew Broughton
    • Check Check One Two
« Reply #3 on: February 02, 2019, 04:13:38 pm »
Many UPS (eg. Cyberpower, APC) have "dry contact" relay connections which can be programmed to engage when the UPS switches to battery power. Attaching that to the GPI connector on the QL would just require wiring up the appropriate connectors and then setting the appropriate GPI IN setting on the console to Transport Stop.
Won't help you though if someone shuts off the console via the power switch on the console, or pulls the AC on the console...
« Last Edit: February 02, 2019, 04:20:54 pm by Andrew Broughton »
-Andy
boburtz
« Reply #4 on: February 06, 2019, 11:47:08 pm »
Fixed it. For anyone interested in how, it went like this:
The console is plugged into a ups.
I plugged a 120v dry contact relay into a non-ups outlet, and wired that to the gpi input.
The gpi is programmed to stop the recorder instantly when mains power is cut to the relay.
Pretty simple solution, works like a charm.
« Reply #5 on: February 06, 2019, 11:51:29 pm »
Simple and elegant. Thanks for sharing your solution.  :)
« Reply #6 on: February 09, 2019, 03:27:06 am »
Bob,  would a time delay be handy to stop nuisance trips?
Sent from my VS996 using Tapatalk
River Delta Audio is now:
boburtz
« Reply #7 on: February 09, 2019, 01:02:47 pm »
I suppose that could come in handy in certain situations. I actually set the gpi to trigger the "autorecord", so it doesn't stop recording completely, it simply track increments. I'll lose a couple of seconds on the recording, but if it was a quick false alarm type power drop (?), I won't need to remember to start the recording again. If it truly is a power down, the restarted recording will just be the last one on the drive and unusable. No loss.
« Reply #8 on: February 10, 2019, 01:55:23 am »
Ok, yes that was my concern, a short power "burp", one easily mitigated by the UPS, would cause loss of recording.  You have addressed this contingency in what sounds like an elegant way.
It's interesting the way software and hardware people think.  If I was charged with this task I would have used a Raspberry Pi or some other tiny computer, connected to the control interface on the UPS then wrote out an OSC or XML event to the board to initiate the record shutdown.
Andrew Broughton
« Reply #9 on: February 10, 2019, 12:29:05 pm »
No need when the hardware is already part of the console (i.e. GPI).
As I mentioned, if you were planning this functionality from the get-go, grab a UPS that already has dry contact outputs built-in, and then all you would need is a cable connecting the UPS and console and voila!
-Andy
Page created in 0.065 seconds with 23 queries.
