Church and H.O.W. – Forums for HOW Sound and AV - Your Displayed Name Must Be Your Real Full Name To Post In The Church and HOW Forums > H.O.W. AV
Need options for overlaying lyrics on video for overflow room
TJ (Tom) Cornish:
--- Quote from: Taylor Hall on January 30, 2019, 02:52:39 PM ---The newer ATEM models have scalers on the inputs and outputs, so that's less of a concern. We were able to seamlessly project multiple 4:3 and 16:9 sources without skipping a beat, though the Roland we settled on does that as well. Didn't screw with framerates at all, but we had a few decimators in our inventory already so we weren't worried.
--- End quote ---
Some do, some don't. The 4K Studio Pro does; the Studio HD and Studio Pro HD don't, I believe.
brian maddox:
--- Quote from: TJ (Tom) Cornish on February 01, 2019, 04:35:13 PM ---Some do, some don't. The 4K Studio Pro does; the Studio HD and Studio Pro HD don't, I believe.
--- End quote ---
Yes. After a bit of digging that's what i found as well.
I will say that this is the first switcher BMD has marketed that had format conversion, so that's a fairly cool thing...
Corey Scogin:
Thanks again all for the advice. I'm learning a lot.
I've most likely settled on the BMD ATEM Television Studio HD.
The plan is to use the program output for the lyrics-over-video overflow room feed and the aux out to mirror the computer lyrics input.
I read through that manual and compared it with the BMD ATEM Production Studio 4k. There seem to be a few features missing compared to the cheaper one above such as picture-in-picture ability but with the added 4k compatibility which I do not need. Everything else seems to be on-par.
Do you all have a recommendation between these models or is it a wash for my simple use case?
brian maddox:
--- Quote from: Corey Scogin on February 01, 2019, 11:43:10 PM ---Thanks again all for the advice. I'm learning a lot.
--- End quote ---
Well, not to beat a dead horse, but the HD model does not convert formats on its inputs so you may end up needing more hardware even with only two inputs if you go that route. I have idea what the cost difference is so I do t really know which is the more economical choice. I have used the 2/3 rack space unit, and found it easy to use and very flexible, so if it meets your needs, I think you’ll be happy with that as a choice.
Erik Jerde:
As has been discussed BMD hasn’t been so good about dealing with varying frame rates. I remember reading that they had really crummy 1080i support on cameras or switchers too at one point.
I’d probably roll with the cheap unit then use decimator MD-HX units with their built in DUC to massage signals to the necessary format. Hopefully you can set the ATEM signal format to be correct for your projector and then bring the camera in at the same settings. Then if you need it different at the overflow location you just slap in a decimator there. Take a look at your signal format needs though and decide off of that.
Navigation
[0] Message Index
[*] Previous page
Go to full version
