Pages: 1 2 3 [4]   Go Down
Author Topic: Suggestions wanted for small church improvement in sound reinforcement  (Read 8989 times)
Mike Caldwell
  • Covington, Ohio
Re: Suggestions wanted for small church improvement in sound reinforcement
« Reply #30 on: March 09, 2019, 11:08:53 PM »
I appreciate Mike's detailed discussion about wire size for speakers. That makes good sense to me. I wonder if you have a preference for connectors -- 1/4 "jacks VS speakons. (Neutrik)
BTW, I used 14 gauge wire (AmazonBasics 14-Gauge Speaker Wire - 99.9% Oxygen Free Copper - 200 Feet)
Speakons are far better they have much more contact surface area
and they will not unplug with an accidental tug on the cable.
Dan Courtney
« Reply #31 on: December 16, 2019, 04:08:19 PM »
I did go with the Speakons ... and I can now see why you recommended them.
We are planning on soon adding a powered subwoofer, front and center. (EKX-15SP). We plan on sending the signal from an Aux on our SoundcraftUi24r (and linking it to the master slider).
Our goal is to run our bass through the new subwoofer instead of our FOH speakers.
Mike Caldwell
  • Covington, Ohio
« Reply #32 on: December 17, 2019, 10:07:12 AM »
The bass will still need to go to the main FOH speakers to get the mid range/hi end definition, bringing up the aux feed to the sub brings in the needed low frequency content.
That is the same for any inputs that needs low frequency enhancement.
The aux for the sub feed should be set post fade.
The main FOH speakers should be high pass filtered at around 100hz, set the sub woofer low pass frequency accordingly.
Dan Courtney
« Reply #33 on: December 17, 2019, 09:04:43 PM »
Those suggestions are appreciated. Merry Christmas !
Pages: 1 2 3 [4]   Go Up
Page created in 0.038 seconds with 25 queries.
