Srx 835 passive spec's
(1/2) > >>
Bob Kidd:
Looking at specs of 835 it appears 725s have a bit more wattage:
835 8 ohm
Power Handling: 3200W Peak, 1600W Program, 800W Continuous
725 4 ohm
Power Rating (Continuous; Program; Peak):
- Passive: 1200 Watts; 2400 Watts; 4800 Watts
Moving 725s and hanging 835s.
Steve Ferreira:
What the specs don't tell us is the sensitivity of the 835s. The 835 will "throw" a bit further with it's narrower horn. The 725s also have an extra 15" driver.
Tim McCulloch:
--- Quote from: Bob Kidd on January 22, 2019, 10:24:32 am ---Looking at specs of 835 it appears 725s have a bit more wattage:
835 8 ohm
725 4 ohm
--- End quote ---
No, it doesn't have "more wattage" unless you are in the business of converting voltage to heat.
Will Knight:
What is it about the 725's you're unhappy with that the 835's would address?
The 725's, on paper, are more efficient (99 dB SPL vs. 95 dB SPL) than the 835's with a max SPL of 136 dB vs. 130 dB.  On the other hand, the 725 is 5 lbs heavier (100 vs. 95) and doesn't get as low as the 835 (53Hz vs. 43Hz).  Have not heard the 835 but would imagine the sound difference to be negligible overall with the 835 appearing to be a bit clearer and more forward due to the MF driver.
Bob Kidd:
--- Quote from: Will Knight on January 22, 2019, 11:31:33 pm ---What is it about the 725's you're unhappy with that the 835's would address?
--- End quote ---
Thanks Will,
In looking at specs that was my concern I comparing the 2, guess should have pointed more at the efficiency then wattage. Wouldn't be a big difference in perceived loudness, but definitely don't won't to take step back. The reason I'm moving to 835 is ability to fly. My current 725s not flyable.
Navigation
[0] Message Index
[#] Next page
Go to full version
