Author Topic: FS: Brand New EWI MC-770 Stand Case for 20 tripods  (Read 356 times)
Raul Suarez
    • Third Ear Sound
« on: January 15, 2019, 03:12:38 pm »
We bought this and then decided to go another route. So this has never been used.  10% less than from EWI?  If you are local and pick up from us you would save freight also which was considerable.
This is the EWI Tourcase tm Model MC-770 microphone stand case.
The case is equipped with 20 removable inner tubes. The tubes measure 35" in length and 4 1/8" in diameter and are designed to fit most collapsible tri-pod mic stands
The side panels are constructed with 3/8 inch hardwood plywood and covered with a black ABS laminate surface. The extrusion is all aluminum and assembled with aluminum rivets. Padded flip handles, 6 total, are arranged both vertically and horizontally on both sides to allow lifting of the case from any orientation and are backed with washers to ensure strength and durability. The removable cover (lid) is held closed with 4 recessed butterfly latches.
The MC-770 is equipped with four 4" swivel casters, two of which are locking style. The casters mount to a 3/4" plywood caster board.
This case is manufactured to exacting tolerances with excellent fit and finish.
Raul Suarez
General Manager
Third Ear Sound
Page created in 0.073 seconds with 22 queries.
