Author Topic: dante io  (Read 1635 times)
Brian Hancock
dante io
« on: January 11, 2019, 12:42:57 pm »
looking for suggestions on dante io box ... ideally 1ru or similar 4 in 4 out or similar ... what have you used what works well etc.
thanks
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: dante io
« Reply #1 on: January 11, 2019, 01:27:59 pm »
thanks
Sound Devices MD-4
Studio Technologies Model 5414
You will find these to be Very Similar Products.  :)
I've used these a lot.  Rock solid product.
brian maddox
bdmaudio@gmail.com
Brian Hancock
Re: dante io
« Reply #2 on: January 12, 2019, 10:22:14 am »
Sound Devices MD-4
Anyone know if there is a SE distributor for sound devices ... love to see some and discuss our needs ??
brian maddox
Re: dante io
« Reply #3 on: January 12, 2019, 07:09:39 pm »
Sorry if this is a stupid question.
by SE do you mean Southeastern region of the US?  There are several Sound Devices "Stocking Partners" in Atlanta and Orlando.
brian maddox
bdmaudio@gmail.com
Greg Bellotte
  • SLC, UT
    • www.MambaFiber.com
Re: dante io
« Reply #4 on: January 12, 2019, 10:21:43 pm »
David Prentice at Dale Pro Audio has always been a good guy to deal with. I buy a bit of Dante from him. Tell him I sent you.
The MD-4 is a great unit, I have several if you need any info. We also use...
RDL RU-MLB4p / RU-LB4p which are throwdown 4x4 with / without mic pres.
AtteroTech uNDIO2x2 throwdown 2x2 with mic pres.
Neutrik NA2-IO-DLINE throwndown 2x2 line level
Tascam ML-16D 16x16 line level 1RU
Ferrofish A32 Dante 32x32analog/64x64MADI/64x64 Dante 1RU
very happy with all of these products and continue to buy more of all of them.
timing is everything...
www.MambaFiber.com
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
Re: dante io
« Reply #5 on: January 12, 2019, 10:32:06 pm »
thanks
The Sound Devices MD-4 got a pretty ho hum review from the very detail oriented Langson Holland over on the Syn-Aud-Con forums, however that was specifically for measurement I/O
I have been looking at the Shure ANI4IN and ANI4OUT combo myself.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Phillip Ivan Pietruschka
Re: dante io
« Reply #6 on: January 14, 2019, 06:18:40 pm »
The two 4i/4o boxes I use are the ST 5414 and Extron AXI-44AT. Both have some front panel controls, for preamp gain etc. The Extron is much smaller, 1/3RU, and has phoenix connectors instead of XLRs. Its fidelity makes its useful for utility applications rather than principal IO - i use it to connect link a dante network to a matrix intercom system.
I guess I have a different understanding of 'throwdown' to Greg, as Im not sure why units with phoenix connectors would qualify for such description - like the atterotech unit (which I also use, and are fine, but not 4x4).
Be aware of the flow limitations with the 4x4 units; as most or all of them will still use the Ultimo chipsets, which from memory are constrained to 2 flows in each direction. It is also worth paying attention to the control options and gain resolution with some of these smaller units, they may not be what you initially expect coming from larger and more fully featured units.
Henry Cohen
  • Westchester Co., NY, USA
Re: dante io
« Reply #7 on: January 14, 2019, 08:11:10 pm »
Glensound's AIOP44 is a bare bones 1RU Dante line level 4 ch I/O using the Ultimo chip. About $600.00. They've proven very durable and work like a charm.
Henry Cohen
brian maddox
Re: dante io
« Reply #8 on: January 14, 2019, 08:20:00 pm »
This is cool.  Gonna bookmark for future use....
« Last Edit: January 15, 2019, 08:55:29 pm by brian maddox »
brian maddox
bdmaudio@gmail.com
Steve Anderson
Re: dante io
« Reply #9 on: January 15, 2019, 01:52:51 am »
I believe the Ultimo is only limited to 2 x 2 when using at 88.2/96K... at 44.1/48K they are 4 x 4.
Re: dante io
