Author Topic: Truss trolley  (Read 2201 times)
Mal Brown
Truss trolley
« on: December 18, 2018, 10:12:37 am »
https://briteq-lighting.com/bt-truss-29-trolley-stack
Found this on line.  Not available on this side of the pond.   Looks like a starting place for a DIY experiment though.
I have Global F33.  11 7/16Ē triangle.  Would like to space them a few inches apart for transport with LED Ďslim parsí attached.  Truck ramp is a little over 27 wide so there would be some hangover...  maybe over the holiday break Iíll get a little time in on it.  2 wide 4 high would solve some transport issues for me.
Bass player, sound guy.
Fb Gorge Sound and Light
WillyandNelson.com
Taylor Hall
Re: Truss trolley
« Reply #1 on: December 18, 2018, 12:05:52 pm »
We built something similar for our box truss but without the braces going over the top. Just took some 2x4" box aluminum, mounted wheels and heavy duty lighting clamps to it and then strap it all together with ratchet straps. The bottom two sticks are secured by the clamps and everyone else gets strapped to those.
Since you're using triangle, you could pretty easily go three sticks per level if you rotate the middle stick 180į to fit in the valley created by the other two, like this: \/ /\ \/
Just be sure you space the two dollies out properly so you don't high-side your sticks rolling them onto the truck.
1) Do it right
Mal Brown
Re: Truss trolley
« Reply #2 on: December 18, 2018, 12:14:10 pm »
Spacing - good point !
3 per level. Trying to leave my led par washed attached. I donít think I could accomplish that at 3 per level.
WillyandNelson.com
TJ (Tom) Cornish
  • St. Paul, MN
Re: Truss trolley
« Reply #3 on: December 18, 2018, 12:21:23 pm »
Probably not compatible with your truss, but here's another take on the issue: https://trusst.com/products/ct290-dlykit-truss-dolly-kit/ (look at all the pictures to see how they space the layers out)
Taylor Hall
Re: Truss trolley
« Reply #4 on: December 18, 2018, 12:56:34 pm »
Ahhh, right, forgot that part. Do all your sticks have lighting attached? perhaps the bottom row or two could be three wide then move to two wide for all the pre-mounted sticks. Lowering the center of gravity with these will help out a ton, maneuvering a 5-high stack of 16" box taught us that very quickly!
That's what we emulated when making ours, and for way cheaper than the $300 they retail for.
1) Do it right
Mal Brown
Re: Truss trolley
« Reply #5 on: December 31, 2018, 09:05:18 pm »
Trollies are fabbed so most of the way there.  Need to mount hooks for strapping and fab more of inter layer stacking guides.  Have the patterns created though so for 1 day in, good progress.
https://www.facebook.com/923463794403865/posts/2009886299094937/
Unfortunately I donít have a way to shrink my photo to 512k on my iPad
Here is a link to the same info at Talkbass if you are interested and not a facebooker.
https://www.talkbass.com/threads/diy-truss-trollies.1380868/
« Last Edit: December 31, 2018, 10:01:09 pm by Mal Brown »
WillyandNelson.com
Taylor Hall
Re: Truss trolley
« Reply #6 on: January 02, 2019, 08:59:46 am »
Looking good! Careful with those casters going over thresholds and large bumps, though. There's not much meat there for those bolts to grip to, so a few good jolts could rip them right through your wood. We ran into that issue with some older sub dollies we made, so we used a few metal plates to sandwich either side of the wooden base and never had an issue since then.
1) Do it right
Mal Brown
Re: Truss trolley
« Reply #7 on: January 03, 2019, 12:00:48 am »
Hmm.  Maybe a set of fender washers would do the trick?
WillyandNelson.com
Taylor Hall
Re: Truss trolley
« Reply #8 on: January 04, 2019, 07:42:16 am »
It's a good place to start, I'd get the beefiest ones you can find and see how they hold up after a gig or two.
1) Do it right
Mal Brown
Re: Truss trolley
« Reply #9 on: January 05, 2019, 08:14:52 pm »
One more set of layer guides to go. Think I may do a redesign on the rolling basses.  Itís close but what the heck, itís just plywood...  I added a second guide for the inner two rails on the bases.  That stabilized things a bit.  I think a slightly square base may be helpful.   Also, I want to accommodate some support for the bolts as Taylor suggested and that will mean new basses anyway as my guides are glued and screwed...
https://www.talkbass.com/threads/diy-truss-trollies.1380868/#post-22168900
Same thread link at TalkBass.  Work in process pic at the bottom.
« Last Edit: January 05, 2019, 08:20:20 pm by Mal Brown »
WillyandNelson.com
Re: Truss trolley
¬ę Reply #9 on: January 05, 2019, 08:14:52 pm ¬Ľ
Page created in 0.043 seconds with 24 queries.
