While my solution is not redundant, the OP did not specify redundant. My solution is zero dollars, however.
this is of course a very bad way of doing a redundant system..it will work until the #1 computer fails and then what do you do? no back up!
without knowing which generation are your mackbooks (do they have usb a b or c or thunderbolt ports etc..)
the easiest method is to use the midi out 5 pin din from the m32 feeding to a midi splitter (1 in 2out for ex.) and then feed those to 2 identical usb /midi interfaces which in turn each feed they're own computers....
Although, you could use one midi signal out of the ethernet port and send that to one comp and another from the usb dn32 and do the same.......its not clear from the docs that you could do this simultaneously...but that might work .....give it a try and report back....
hope that helps
Ray
