Author Topic: Digico SD5 talkback mic.  (Read 819 times)
Al Rettich
« on: November 01, 2018, 07:13:01 pm »
So what Iíve been told is the TB is on the back of the desk in one of the analogue mic inputs.  Anyone ever use like a podium mic? If so, how did it fair?
Mike Caldwell
  • Covington, Ohio
Re: Digico SD5 talkback mic.
« Reply #1 on: November 01, 2018, 08:45:46 pm »
I have no clue what Digico does in the way of a talk back connection or operation but for my needs I like using a headset mic as a talk back when I need a talk back mic.
The AT PRO 8HEx works great.
Erik Jerde
« Reply #2 on: November 01, 2018, 09:03:32 pm »
This is correct.  You can use any input in your system as a source for talkback.  There is no dedicated TB input.  As far as a podium mic, it really depends on your situation.  If you're in a loud rock setup where you're going to introduce a lot of feedback then it's a bad idea.  I once modded a CB radio handheld mic with push button as a TB and that worked great till it walked off one day.  I guess someone else thought it worked great too.
  • Old enough to know better
  • Audio Plumber
« Reply #3 on: November 01, 2018, 10:40:48 pm »
I would expect a cardioid or hypercardioid lectern mic to be far less susceptible to feedback than an omni fist mic from a CB or walkie talkie. Neither one would be my first choice either for sound quality or GBF. A handheld switch mic that you pick up and talk into is a better choice.
Jim Roach
« Reply #4 on: November 03, 2018, 04:09:45 am »
I have used a a Shure SM99 plugged directly into a local input on an SD8 and bent back over the desk. This is an installed system with monitors from FOH so I dimmed the monitors when the TB is engaged. It's never routed to the house. In every other situation, I use a switched handheld mic as Mac suggested above.
The meter bridge on an SD5 would necessitate using a cable and a mic stand with the podium mic pretty much making it pointless.
Scott Helmke
« Reply #5 on: November 03, 2018, 11:46:52 am »
http://www.shure.com/americas/products/microphones/other/514b-voice-communication-microphone
