Pages: 1 2 [All]   Go Down
Author Topic: Expression 3 and Visi remote  (Read 565 times)
Steve Ferreira
« on: October 22, 2018, 11:22:36 am »
Hi all,
Console running latest fw 1.8 build 6. Ipad 2 with latest fw as well.
I tried to connect through a dlink Dap-1350. I can't get dhcp on the console from the router. When i did set the router to access point and a static ip I can get the console and ipad to see each other, but it then drops out.
I tried running static ip and in router mode but can't get both to talk to each other and the console doesn't get a dhcp. I spend way too much time and even watched videos online. I really am stumped as to why i can't get both to talk to each other. Also did an SD card format and reloaded the firmware.
Can the router be the issue in router mode as it needs to get a dhcp from a modem? Even in router mode i can connect with the ipad into it's ip page to configure the router.
https://www.bhphotovideo.com/c/product/769020-REG/D_Link_DAP_1350_Wireless_N_Pocket_Router.html
Any help would be great.
Thanks
Dave Garoutte
  • San Rafael, CA
Re: Expression 3 and Visi remote
« Reply #1 on: October 22, 2018, 12:00:21 pm »
Do you have a different router you can try?
Inventor.
Steve Ferreira
« Reply #2 on: October 22, 2018, 12:47:25 pm »
I will have to go buy one. I was trying to re-purpose a unit i had sitting at home.
« Reply #3 on: October 22, 2018, 01:02:30 pm »
A router (as defined by IT folks, not Best Buy or consumer-speak) doesn't need a modem for DHCP, as the router is what assigns IP addresses (the DHCP server is internal to the router).
Some consumer items *may* be different from their commercial/professional counterparts because most consumers are ill-equipped to do more than plug in the power supply... and I have no experience with your little pocket router/AP.
The reason you can't get the devices to "talk" to each other is simple - they don't have IP addresses in the same subnet (or are unaddressed).
Steve Ferreira
« Reply #4 on: October 22, 2018, 01:09:46 pm »
Even with the console setup to recieve dhcp from the router and following Soundcraft's instructions I can't get an ip address. I tried static ip in the correct subnet and correct ip range and still can't get a connection.
« Reply #5 on: October 22, 2018, 01:11:38 pm »
Then the router is defective, most likely.
Dave Pluke
    • BIGG GRIN Productions
« Reply #6 on: October 22, 2018, 08:04:08 pm »
Just to rule out something simple; the Console is connected to a LAN port on the router, correct?
Dave
Dave Garoutte
  • San Rafael, CA
« Reply #7 on: October 22, 2018, 09:50:25 pm »
Dave
+1
I've been bitten by this.
Inventor.
Steve Ferreira
« Reply #8 on: October 22, 2018, 09:54:01 pm »
Dave
Router on has 1 lan/wan port. I'm beginning to think that this little router can't do what i want it to do.
Jon Dees
« Reply #9 on: October 23, 2018, 04:11:39 pm »
My 2 Performers hate DHCP and really hate admitting that you just assigned it a static Ip. Suggest you turn off the desk, turn on DHCP and then re turn on the desk. If that fails then attempt to assign static IP multiple times and you might hit the lotto.
Dave Pluke
« Reply #10 on: October 23, 2018, 06:41:30 pm »
Sounds more like a Modem or Access Point to me.  Yes, get a fresh start with a new (multiport) router.
Dave
Steve Ferreira
« Reply #11 on: October 25, 2018, 11:58:42 am »
Update:
I purchased a new router last night, setup up port 3333 in UDP and set the console to dhcp. Powered the console back down and connected everything up. Voila, ip address and connectivity to visi remote.
Thanks all for the help
Pages: 1 2 [All]   Go Up
Page created in 0.082 seconds with 21 queries.
